[GRASS-dev] [GRASS GIS] #3369: Followup to area calculation fix in changeset 71169
trac at osgeo.org
Mon Jul 10 17:55:50 PDT 2017
Reporter: ndawson | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: unspecified
Resolution: | Keywords:
CPU: Unspecified | Platform: Unspecified
Comment (by ndawson):
> About the first example (regression14675): what is SRSid 145L in EPSG or
proj4 terms?
Argh, missed that sorry. It's EPSG:2154.
> About the second example (regression16820): GRASS reports an area of
43.3280133198665 sqm in the original CRS, and an area of 43.2035658006178
sqm reprojected to latlon. The QGIS test has a reference of 43.183369 sqm,
i.e. the projected GRASS result is a bit closer to the original than the
QGIS reference. The threshold as used in GRASS seems to work fine here.
Hmm - good point. To eliminate any discrepancies due to projection
handling/some other factor I tried using the original threshold of 1e-6 in
QGIS and got an area of
43.3280029296875.
I can't find a reliable threshold which satisfies both these requirements.
Ubuntu 16.04 with a threshold of 0.8e-7 does, but the same threshold on
Fedora 25 fails both tests.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3369#comment:2>
