[GRASS-dev] [GRASS GIS] #3374: r.import inconsistent behavior when using r.in.gdal and r.proj
GRASS GIS trac at osgeo.org
Tue Jul 18 12:25:55 PDT 2017
 Reporter:  annakrat                     |      Owner:  grass-dev@…
     Type:  defect                       |     Status:  new
 Priority:  normal                       |  Milestone:  7.4.0
Component:  Raster                       |    Version:  svn-trunk
 Keywords:  r.import, r.in.gdal, r.proj  |        CPU:  Unspecified
 Platform:  Unspecified                  |
 Module r.import has options for output resolution and extent, but they are
 basically ignored when coordinates system matches and r.in.gdal is used,
 they are used only when reprojecting. So when there is no reprojection
 needed:
 1. r.in.gdal has new -r flag, so that should be used if extent=region
 2. when resolution=value or resolution=region, r.import should resample
 the raster. The default (resolution=estimated) means r.in.gdal uses
 resolution of the raster as it is now.
 Any objection to this behavior?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3374>
