[GRASS-dev] [GRASS GIS] #2940: Compiling Grass-7.0.3 under FreeBSD: tplot directory (with log)
GRASS GIS trac at osgeo.org
Sat Jul 22 02:09:45 PDT 2017
  Reporter:  pieside  |      Owner:  grass-dev@…
      Type:  defect   |     Status:  new
  Priority:  normal   |  Milestone:  7.2.2
 Component:  Default  |    Version:  7.2.0
Resolution:           |   Keywords:  FreeBSD
       CPU:  x86-64   |   Platform:  Other Unix
Comment (by neteler):
 Replying to [comment:8 lbartoletti]:
 > Hi,
 > I've tried to build grass 7.2 on our poudriere system (FreeBSD 11 amd 64
 without success). Here the
 [https://gist.githubusercontent.com/lbartoletti/dee8bb053df33682f82af9bae834fdb8/raw/bb9e8b80deadfacf4d7b8b96c8808141d329a3d1/gistfile1.txt
 log] and the [https://forums.freebsd.org/threads/56558/#post-334096
 discussion on FreeBSD Forum.]
 > I can't be present at FOSS4G-E code sprint, but if something can help us
 Yes :)
 So, the log contains:
 env: python: No such file or directory
 The reason is that there is not link from python2.7 --> python on your
 system (or it is not in $PATH), so that the first line in GRASS' Python
 scripts fails:
 #!/usr/bin/env python
 A lot of the errors there might be secondary ones due to this link
 missing.
 Can you add this link, try again and report here?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2940#comment:10>
