[GRASS-dev] [GRASS GIS] #2940: Compiling Grass-7.0.3 under FreeBSD: tplot directory (with log)
trac at osgeo.org
Sat Jul 22 07:02:58 PDT 2017
Reporter: pieside | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Default | Version: 7.2.0
Resolution: | Keywords: FreeBSD
CPU: x86-64 | Platform: Other Unix
Comment (by neteler):
Replying to [comment:11 lbartoletti]:
> Normally, Python is already present.
> It does not matter, I'll start from scratch. Here's what I get by
compiling directly
[https://raw.githubusercontent.com/lbartoletti/grass7/master/build_log
log].
Here is a line from your log, appearing for most t.* modules:
gmake[5]: Entering directory
'/usr/home/Loic/grass7/work/grass-7.2.0/temporal/t.create'
/usr/bin/install -c t.create.py
/usr/home/Loic/grass7/work/grass-7.2.0/dist.amd64-portbld-
freebsd11.0/scripts/t.create
if [ "/usr/home/Loic/grass7/work/grass-7.2.0/dist.amd64-portbld-
freebsd11.0/scripts/t.create" != "" ] ; then
GISRC=/usr/home/Loic/grass7/work/grass-7.2.0/dist.amd64-portbld-
freebsd11.0/demolocation/.grassrc72
GISBASE=/usr/home/Loic/grass7/work/grass-7.2.0/dist.amd64-portbld-
freebsd11.0 PATH="/usr/home/Loic/grass7/work/grass-7.2.0/dist.amd64
-portbld-freebsd11.0/bin:/usr/home/Loic/grass7/work/grass-7.2.0/dist.amd64
-portbld-freebsd11.0/scripts:$PATH"
PYTHONPATH="/usr/home/Loic/grass7/work/grass-7.2.0/dist.amd64-portbld-
freebsd11.0/etc/python:/usr/home/Loic/grass7/work/grass-7.2.0/dist.amd64
-portbld-freebsd11.0/gui/wxpython:$PYTHONPATH"
LD_LIBRARY_PATH="/usr/home/Loic/grass7/work/grass-7.2.0/dist.amd64
-portbld-
freebsd11.0/scripts:/usr/home/Loic/grass7/work/grass-7.2.0/dist.amd64
-portbld-freebsd11.0/lib:/usr/home/Loic/grass7/work/grass-7.2.0/dist.amd64
-portbld-freebsd11.0/lib:" LC_ALL=C
freebsd11.0/scripts/t.create --html-description < /dev/null | grep -v
'</body>\|</html>' > t.create.tmp.html ; fi
File "/usr/home/Loic/grass7/work/grass-7.2.0/dist.amd64-portbld-
freebsd11.0/scripts/t.create", line 62, in <module>
import grass.temporal as tgis
freebsd11.0/etc/python/grass/temporal/__init__.py", line 3, in <module>
from .core import *
freebsd11.0/etc/python/grass/temporal/core.py", line 45, in <module>
from .c_libraries_interface import *
freebsd11.0/etc/python/grass/temporal/c_libraries_interface.py", line 28,
in <module>
from grass.pygrass.rpc.base import RPCServerBase
freebsd11.0/etc/python/grass/pygrass/rpc/__init__.py", line 21, in
<module>
from grass.pygrass.vector import *
freebsd11.0/etc/python/grass/pygrass/vector/__init__.py", line 13, in
<module>
from grass.pygrass.vector.vector_type import VTYPE
freebsd11.0/etc/python/grass/pygrass/vector/vector_type.py", line 9, in
<module>
from grass.pygrass.vector import geometry as geo
freebsd11.0/etc/python/grass/pygrass/vector/geometry.py", line 12, in
<module>
import numpy as np
File "/usr/local/lib/python2.7/site-packages/numpy/__init__.py", line
142, in <module>
from . import add_newdocs
File "/usr/local/lib/python2.7/site-packages/numpy/add_newdocs.py", line
13, in <module>
from numpy.lib import add_newdoc
File "/usr/local/lib/python2.7/site-packages/numpy/lib/__init__.py",
line 8, in <module>
from .type_check import *
File "/usr/local/lib/python2.7/site-packages/numpy/lib/type_check.py",
line 11, in <module>
import numpy.core.numeric as _nx
File "/usr/local/lib/python2.7/site-packages/numpy/core/__init__.py",
line 14, in <module>
from . import multiarray
ImportError: /lib/libgcc_s.so.1: version GCC_4.6.0 required by
/usr/local/lib/gcc5/libgfortran.so.3 not found
gmake[5]: *** [../..//include/Make/Html.make:14: t.create.tmp.html] Error
1
... to be fixed on your server.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2940#comment:12>
