[GRASS-dev] [GRASS GIS] #3368: warnings and errors in compilation log
trac at osgeo.org
Sun Jul 23 13:48:32 PDT 2017
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.0
Component: Compiling | Version: svn-trunk
Resolution: | Keywords:
CPU: Unspecified | Platform: All
Comment (by mmetz):
Replying to [ticket:3368 hellik]:
> looking into the
[https://wingrass.fsv.cvut.cz/grass73/x86_64/logs/log-r71243-290/
package.log] regarding warnings and errors during compilations in windows
(zipped log file attached), there are some warnings and error (AFAIR I've
seen them also in my debian 9):
There will be many more compiler warnings with different compiler flags,
e.g. -Wall -Wextra -Wpedantic -Wshadow
As of trunk r71288, some of the warnings have been removed.
The errors in ctypes parsing C headers seem to be harmless, ctypes is
apparently working anyway. Getting rid of these error messages would be a
nice to have.
About the remaining compiler warnings:
There are various warnings like
warning: assignment discards 'const' qualifier from pointer target type
These are mostly harmless, it would be nice to get rid of them.
About iconv
MS Windows
parser_interface.c: In function 'print_escaped_for_xml':
parser_interface.c:67:20: warning: passing argument 2 of 'libiconv' from
incompatible pointer type [-Wincompatible-pointer-types]
ret = iconv(conv, (char **)&src, &srclen, &dst, &dstlen);
In file included from parser_interface.c:32:0:
C:/OSGeo4W64/include/iconv.h:87:15: note: expected 'const char **' but
argument is of type 'char **'
#define iconv libiconv
C:/OSGeo4W64/include/iconv.h:89:37: note: in expansion of macro 'iconv'
extern LIBICONV_DLL_EXPORTED size_t iconv (iconv_t cd,
const char **inbuf, size_t
*inbytesleft,
char **outbuf, size_t
*outbytesleft);
Linux
size_t iconv(iconv_t cd,
char **inbuf, size_t *inbytesleft,
char **outbuf, size_t *outbytesleft);
We could add `#ifdef __MINGW32__` clauses to avoid these warnings, but the
both the standard C and the GNU libiconv version expect `char **inbuf`,
not `const char **inbuf`, therefore I would leave it as it is.
put_row.c: In function 'write_null_bits_compressed':
put_row.c:509:29: warning: passing argument 1 of 'G_lz4_compress' discards
'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
nwrite = G_lz4_compress(flags, size, compressed_buf, size);
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/gis.h:670:0,
from
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/raster.h:4,
from put_row.c:27:
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/defs/gis.h:208:1:
note: expected 'unsigned char *' but argument is of type 'const unsigned
char *'
G_lz4_compress(unsigned char *src, int src_sz, unsigned char *dst,
G_compress() and all G_*_compress() functions would need to be changed to
use const unsingned char *src, same for G_expand() and G_*_expand(). That
would make sense but is a (probably harmless) API change. Considering that
GRASS 7.2 is the first release to feature new compression methods, GRASS
7.2 could be regarded as a tech preview and minor changes in the API
related to the new feature might be ok.
`lib/driver/text3.c` same iconv issue as for parser_interface.c
`lib/cairodriver/text.c` same iconv issue as for parser_interface.c
[...]/include/grass/iostream/empq_adaptive.h: In constructor
'EMPQueueAdaptive<T, Key>::EMPQueueAdaptive(long int)':
[...]/include/grass/iostream/empq_adaptive.h:69:47: warning: delegating
constructors only available with -std=c++11 or -std=gnu++11
EMPQueueAdaptive(long N) : EMPQueueAdaptive() {};
I guess the c++11 standard should not be a requirement. Any suggestions on
how to avoid that?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3368#comment:1>
