[GRASS-dev] v.surf.bspline density and distance estimates
Paulo van Breugel
p.vanbreugel at gmail.com
Mon Jul 24 09:30:53 PDT 2017
On 6/25/17 11:09 PM, Markus Metz wrote:
> On Sat, Jun 24, 2017 at 11:23 AM, Paulo van Breugel
> <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>> wrote:
> > On 6/16/17 3:20 PM, Markus Metz wrote:
> > On Fri, Jun 16, 2017 at 11:28 AM, Paulo van Breugel
> > > Hi devs, can anybody tell how v.surf.bspline computes the point
> density and mean distance.
> > point density is the number of points divided by the size of the
> bounding box of the points
> > mean distance is the square root of the size of the bounding box
> divided by the number of points
> > > And what is the unit, pixels, as also used for length spline steps
> or meters?
> > the unit is map unit, you can then figure out a reasonable
> resolution (in map units) for the current region
> > I think it would be good to add your explanation to the manual page.
> I was trying to come up with a text, but then I realized there is
> still some ambiguity left.
> > According to the manual page, the ns_step and ew_step parameters are
> in pixels (which I would interpret as 'number of pixels'). However,
> the example of 'Basic interpolation and raster output with a longer
> spline step' in the manual page talks about mapping units.
> > v.surf.bspline input=point_vector raster=interpolate_surface
> ew_step=25 ns_step=25
> > A bilinear spline interpolation will be done with a spline step
> length of 25 map units.
> > So if the region's resolution is 100 meter, is the ns_step and
> ew_step 2500 meter (25 pixels) or 25 meters? The former would be more
> conform common practice in grass I think.
> The unit of ns_step and ew_step is map units, but that does not really
> make sense, the unit of the spline steps should rather be pixels.
> However, the unit of the spline step options can not be changed
> because it would break compatibility.
In the manual page, in the first paragraph of the Notes, may I suggest
to change the text:
The length of each spline step is defined by *ew_step* for the east-west
direction and *ns_step* for the north-south direction. Step is defined
in number of pixels.
to something along the lines:
The length (in mapping units) of each spline step is defined by
*ew_step* for the east-west direction and *ns_step* for the north-south
direction.
> Markus M
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170724/2c7703a2/attachment.html>
