[GRASS-dev] Adding hexagonal rasters to GRASS
Luí­s Moreira de Sousa luis.de.sousa at protonmail.ch
Tue Jul 25 06:50:43 PDT 2017
Hi Sören, good to have you in this discussion.
I do not know exactly what the compressed row approach is, but I am pretty positive on it being applicable to hexagonal rasters too. As I wrote initially, an hexagonal mesh can be stored in an array; from then on it is all a matter of cell indexation.
I added the angle rotation to the HexASCII specification since there are two ways to align an hexagon with the Cartesian axis: with two sides parallel to the x axis (North-South orientation) or with two sides parallel to y axis (East-West orientation). With an angle of 0º in HexASCII you get a North-South mesh, with 90º it is a East-West mesh. If other angles complicate matters, on a first approach only angles of 0º and 90º could be considered.
In any case, rotating a mesh by an angle is a relatively simple computation, you can see an example in this method of the hex-utils package:
https://github.com/ldesousa/hex-utils/blob/develop/hex_utils/hasc.py#L235
During my MSc thesis I developed a method to display hexagons in a squared monitor with bitmaps that may be still useful for the d. modules. But perhaps a vector approach is more interesting today.
Cheers.
Luís Moreira de Sousa
Im Grund 6
CH-8600 Dübendorf
Switzerland
Phone: +41 (0)79 812 62 65
Email: luis.de.sousa at protonmail.ch
URL: https://sites.google.com/site/luismoreiradesousa
> -------- Original Message --------
> Subject: Re: [GRASS-dev] Adding hexagonal rasters to GRASS
> Local Time: July 24, 2017 9:24 PM
> UTC Time: July 24, 2017 7:24 PM
> From: soerengebbert at googlemail.com
> To: Vaclav Petras <wenzeslaus at gmail.com>
> Luí­s Moreira de Sousa <luis.de.sousa at protonmail.ch>, grass-dev at lists.osgeo.org <grass-dev at lists.osgeo.org>
> Dear Luí­s,
> this sounds very interesting, especially the improvement for surface
> flow algorithms using hexagonal grids and other mass conservation
> approaches like groundwater flow, heat flow, ... .
> I agree with Vaclav on this topic. I think hexagonal grids can be
> stored using the compressed row based approach of GRASS GIS. In
> addition the rotation of the hexagonal grid may be stored in the
> metadata. The question is, do we need rotated hexagonal grids at all
> or do horizontal hexagonal grids do the job? In case of "horizontal"
> hexagonal grids the compressed row approach would be very fast for
> horizontal access. Indexing can be easily mapped to row/column access
> using the "odd-r" horizontal layout. The existing on the fly nearest
> neighbor resampling algorithms will have an offset of half a cell for
> odd row indices when interacting with normal raster layers in existing
> modules, so they must be adjusted.
> Neighborhood operations must be implemented on top of the existing
> row/col approach of GRASS. All algorithms that make cell neighbor
> computations must be modified. The existing r.mapcalc neighbor
> operators r[x][y] can be reused in case of odd-r horizontal layout.
> Conversion between regular grids and hexagonal grids must be
> implemented. Resampling algorithms must be modified. Rendering of
> hexagonal grids must be implemented in the display library. Plenty of
> work do do. :)
> Best regards
> Sören
> 2017-07-24 1:19 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
>> Dear Luís,
>> On Sun, Jul 23, 2017 at 11:50 AM, Luí­s Moreira de Sousa
>> <luis.de.sousa at protonmail.ch> wrote:
>>> I presented hex-utils at the GISTAM conference in April, here is the
>>> video:
>>> https://www.youtube.com/watch?v=uLO4HDCVBp0
>> thank you, this is very informative and exiting!
>>> But as Luca said during the Q/A, it is probably better to start outright
>>> within GRASS. This will require the abstraction of the raster concept,
>>> together with operations like neighbourhood, number of neighbours, distance
>>> to neighbours, etc. With that done most of the raster modules would function
>>> the same way for squared and hexagonal rasters. Still, this would require a
>>> complete revision of all the raster modules.
>> Sounds good. I think there is a way in GRASS GIS to make it revolutionary
>> and at the same time keeping everything in place. See below.
>>> For a programmer, the main difference between hexagonal and squared
>>> rasters is the cell addressing system: with hexagons the axis are not
>>> orthogonal.
>> If there would be a way, like the abstraction you mentioned, which would,
>> e.g. make the current rectangle-only code work with hexagonal data (e.g. by
>> presenting converting hexagons as rectangles on the fly), that would be
>> helpful, but on the other side, I don"t think it is necessarily the first
>> step if there is an other way how to connect with rectangular rasters (even
>> if it involves converting back and forth or less precision).
>>> However, it is possible to store an hexagonal raster in a bi-dimensional
>>> array like you would store a squared raster.
>> That would help the implementation and hopefully also the integration and
>> adoption, again see below.
>>> I wrote an article last year with full details on the HexASCII file format
>>> and how to deal with hexagonal cell adressing, but it is still under review.
>>> I can not send it to the list, please send me a personal message if you wish
>>> to read it.
>> If you can share it, I would like to see it.
>>> It would be great if we can take this forward. I imagine it is a load of
>>> work, but it will make GRASS an even more awesome system ;)
>> Load of work and resulting code to maintain should be part of the
>> consideration. Using existing functionality (algorithms, formats) and
>> integrating with it will be crucial for both users and developers alike.
>> Can you implement it this as a layer on top of existing functionality in
>> GRASS GIS? There is several examples and concepts in GRASS GIS of this. For
>> example, the temporal (t.*) modules work with series of rasters and vectors
>> registered as spatio-temporal datasets and the image processing (i.*)
>> modules work with series of rasters registered as imagery groups and
>> subgroups ("multiband image"). In both cases standard storage of rasters (or
>> vectors) is used, so there is no new backend format in GRASS database except
>> for the additional data (metadata) needed for these tools. What is important
>> is that you can work with the existing tools on the data handled by temporal
>> or imagery modules, i.e. you can use the existing tools to implement the new
>> tools (e.g. average of spatio-temporal raster dataset can be implemented
>> through a tool for average of multiple rasters) and if the imagery or
>> temporal modules miss specific functionality you need, you can fallback to
>> the standard modules (e.g. loop over members of imagery group).
>> I was thinking that the hexagonal rasters can be implemented in GRASS GIS
>> using two rasters which would be shifted against each other, but aligned
>> with the hexagonal cells, i.e. two rectangular rasters making up one
>> hexagonal raster/grid (but I didn"t test that or examined that more). After
>> seeing your video with slightly rotated hexagonal grid, I"m thinking if it
>> is possible to fit only one raster but with different resolution to the
>> hexagons. The idea is that 1) you don"t need another storage format and 2)
>> you can use the raw data without the hexagon-aware algorithms. Of course we
>> can settle just with re-using the storage format (1).
>> Another approach is to threat hexagonal rasters/grids as another basic data
>> type next to raster maps, vector maps, and 3D raster maps (in GRASS GIS
>> there are also the aforementioned spatio-temporal datasets and imagery
>> groups). They would be connected to the rest where it makes sense. For
>> example, (2D) rasters and 3D rasters are independent, but there is also
>> several connections: there are modules for conversion in between the two
>> types, a lot of code for handling colors is the same, and computational
>> region applies to both and is handled from the same module.
>> If I may ask, what would you need to create a prototype and what do you
>> envision as a final goal?
>> Best,
>> Vaclav
>> grass-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170725/d2f2c450/attachment-0001.html>
