[GRASS-dev] GRASS Mac compiling - cairo problems
Michael Barton
Michael.Barton at asu.edu
Wed Jul 26 16:10:14 PDT 2017
I'm trying to do a basic compilation of GRASS 7.2 on my Mac to get started in a new binary packaging attempt. I'm hitting new issues with cairo and wonder if anyone can shed some light on this.
This is the first time I've tried compiling on my current machine. It is up to date with the newest version of OS X (Sierra, OS X 10.12.6) and current developer tools.
I have William Kyngesburye's cairo framework 12.2-1.
First problem is that configure could not find cairo with the path in the configure string I used last October. I tried a couple of other paths and found one that worked.
When I tried to make GRASS, I ran into the following errors, all related to cairo. cairodriver can't find fonconfig.h, which I think are leading to the rest of the errors.
But fontconfig.h is IN the directory I've pointed to in the --with-cairo-includes= statement.
Here is my configure script:
./configure --with-macosx-sdk=/Developer/SDKs/MacOSX10.8.sdk --with-freetype --with-freetype-includes=/Library/Frameworks/FreeType.framework/unix/include/ --with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib --with-gdal=/Library/Frameworks/GDAL.framework/Programs/gdal-config --with-gdal-libs=/Library/Frameworks/GDAL.framework/Libraries --with-proj --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib --with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj --with-geos=/Library/Frameworks/GEOS.framework/Versions/3/unix/bin/geos-config --with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-cairo --with-cairo-includes=/Library/Frameworks/cairo.framework/Headers/ --with-cairo-libs=/Library/Frameworks/cairo.framework/unix/lib --with-cairo-ldflags="-lcairo" --without-postgres --without-mysql --with-sqlite --with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib --with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include --with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include --with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib --with-x --with-cxx --with-opengl=aqua --without-readline --prefix=/Applications --enable-macosx-app --with-python --with-wxwidgets=/usr/local/lib/wxPython-unicode-2.8.12.1/bin/wx-config --with-macosx-archs="i386 x86\_64" --with-opencl
Here are the errors (I can give a full log dump if it would be helpful):
Errors in:
/Users/cmbarton/grass_source/releasebranch_7_2/lib/cairodriver
/Users/cmbarton/grass_source/releasebranch_7_2/lib/display
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.barscale
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.colortable
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.erase
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.font
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.fontlist
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.geodesic
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.graph
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.grid
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.his
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.histogram
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.info<http://d.info>
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.labels
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.legend
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.legend.vect
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.linegraph
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.mon
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.northarrow
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.path
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.profile
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.rast
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.rast.arrow
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.rast.num
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.rgb
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.rhumbline
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.text
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.vect
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.vect.chart
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.vect.thematic
/Users/cmbarton/grass_source/releasebranch_7_2/display/d.where
/Users/cmbarton/grass_source/releasebranch_7_2/vector/v.label
/Users/cmbarton/grass_source/releasebranch_7_2/misc/m.nviz.script
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Wed Jul 26 17:02:45 MDT 2017
make: *** [default] Error 1
CMB-MacBook-Pro:releasebranch_7_2 cmbarton$ cd /Users/cmbarton/grass_source/releasebranch_7_2/lib/cairodriver
CMB-MacBook-Pro:cairodriver cmbarton$ make
gcc -g -O2 -arch i386 -isysroot /Developer/SDKs/MacOSX10.8.sdk -fno-common -I/Users/cmbarton/grass_source/releasebranch_7_2/dist.x86_64-apple-darwin16.7.0/include -I/Users/cmbarton/grass_source/releasebranch_7_2/dist.x86_64-apple-darwin16.7.0/include -I../driver -I/Library/Frameworks/cairo.framework/Headers/ -I/Library/Frameworks/FreeType.framework/unix/include/ -DPACKAGE=\""grasslibs"\" -I/Users/cmbarton/grass_source/releasebranch_7_2/dist.x86_64-apple-darwin16.7.0/include -I/Users/cmbarton/grass_source/releasebranch_7_2/dist.x86_64-apple-darwin16.7.0/include -DRELDIR=\"lib/cairodriver\" -o OBJ.x86_64-apple-darwin16.7.0/text.o -c text.c
text.c:20:10: fatal error: 'fontconfig/fontconfig.h' file not found
#include <fontconfig/fontconfig.h>
1 error generated.
make: *** [OBJ.x86_64-apple-darwin16.7.0/text.o] Error 1
Thanks
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170726/ccc46733/attachment.html>
