[GRASS-dev] New attempt to update GRASS for Mac
Michael Barton Michael.Barton at asu.edu
Thu Jul 27 20:35:18 PDT 2017
I just discovered something that has probably been giving increasing problems lately. Because I've been building binaries, I have not looked at the grass.app that is built from just running 'make install' in a long time.
It turns out that whatever creates the *.app automatically bundles some version of wxPython. I've been trying to bundle versions made outside of system folders to avoid the SIP issue, but there is code that is grabbing wxPython from somewhere and putting it into *.app/MacOS/etc/python folder inside the app. Hopefully someone reading this can figure out where this is happening and how to control it.
It explains why I have not been able to really test wxPython 4, and maybe even not wxPython 3. Certainly, it is NOT packaging wxPython 4 files into the app, even though I've compiled with explicit paths to the relevant wxPython 4 files.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Jul 27, 2017, at 6:34 PM, Anna Petrášová <kratochanna at gmail.com<mailto:kratochanna at gmail.com>> wrote:
On Thu, Jul 27, 2017 at 8:13 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
It seems that GRASS (at least GRASS for Mac) will only use the system
Python. If I set up an environment in which Anaconda python is default,
GRASS will not start and gives an error message that it will only run with
the system Python. I don't know where this is coming from. It doesn't seem
to be from the python_wrapper script. This will need to be changed if I am
to package Python with GRASS.
What exactly is the error? I know I was able to use GRASS_PYTHON
variable previously to set the python I needed.
Anna
Michael
C. Michael Barton
www: https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7Ecmbarton&d=DwIFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=ejnQRWolrucufjW07P5RKvDkaAo__J6-niGuF5D7eNg&s=97LlCjf7C4a6iG9wGSVOYu1lQuVXSps_-yEnDAGKWIE&e= , https://urldefense.proofpoint.com/v2/url?u=http-3A__csdc.asu.edu&d=DwIFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=ejnQRWolrucufjW07P5RKvDkaAo__J6-niGuF5D7eNg&s=-IglMTXE4z0Ek6alARnfLbHdyXb7iyo7bg3-Gf0Uyb8&e=
On Jul 27, 2017, at 1:33 PM, Anna Petrášová <kratochanna at gmail.com<mailto:kratochanna at gmail.com>> wrote:
On Thu, Jul 27, 2017 at 3:03 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>>
wrote:
On Jul 27, 2017, at 12:46 PM, Anna Petrášová <kratochanna at gmail.com<mailto:kratochanna at gmail.com>> wrote:
I think you can use pip to install it with whatever Python you use, at
least that's what works on Linux.
How do you specify which Python in pip?
It uses whichever Python is first on the path, you can find out with
which python
probably you can use also something like this:
https://urldefense.proofpoint.com/v2/url?u=https-3A__stackoverflow.com_a_4910393_1058453&d=DwIFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=MCkZA0y-uOGAo8gOeYPoP_uqc1lzXM6XCXuCQayAyS0&s=_vBpVdLmTTjrHrftXdNANYEvTAotd9_enwM-I1H_YFQ&e=
Michael
C. Michael Barton
www:
https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7Ecmbarton&d=DwIFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=MCkZA0y-uOGAo8gOeYPoP_uqc1lzXM6XCXuCQayAyS0&s=9rsZ1tUV9snbiCH4rN8yrhhd4hDrfvamcPxF7y3cvRE&e=
https://urldefense.proofpoint.com/v2/url?u=http-3A__csdc.asu.edu&d=DwIFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=MCkZA0y-uOGAo8gOeYPoP_uqc1lzXM6XCXuCQayAyS0&s=8dy6hAPGI8vce9HOn68hYqtyg7hzPG5nT_Nt0fQIGCk&e=
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170728/2c1f3c34/attachment-0001.html>
