[GRASS-dev] Dockerfile now in repo
Vaclav Petras wenzeslaus at gmail.com
Sat Jul 29 16:11:59 PDT 2017
[Using the thread with the announcement for this answer.]
On Sat, Jul 29, 2017 at 4:00 PM, Michael Barton <Michael.Barton at asu.edu>
wrote:
> Is this a runnable version of GRASS under Docker or a compilable version
of GRASS?
It is the Dockerfile. You let Docker build a Docker image using that file
(Docker looks to the directory specified and finds the Dockerfile, kind of
like make and Makefile). You then use Docker to run a process in the
container derived from that image. GRASS GIS is build as part of building
of the image. See the readme file for examples:
https://trac.osgeo.org/grass/browser/grass/trunk/README#L53
Vaclav
On Sat, Jul 29, 2017 at 12:15 PM, Vaclav Petras <wenzeslaus at gmail.com>
wrote:
> Hi all,
> I just added a Dockerfile to the Subversion repository. The Dockerfile
> uses the local source code, i.e. typically what you get with svn, because
> it is a part of the source code. It it not downloading any GRASS GIS source
> code by itself, so you can make changes in the source code locally and
> rebuild the image (you need to tell Docker to remove the existing image
> (layer) or to not use cache).
> It is using Ubuntu, but something more lightweight may be more
> appropriate, some other images, on the other hand, may bring some
> additional features. It is not installing any GRASS addons or using PPA
> repositories.
> The documentation is in the README (yes, we have a README file ;-). I hope
> it is the right place. It contains example which runs all the tests. It
> assumes you have NC SPM location on your (local) disk.
> The image keeps the source code (the source code is not removed) and it
> has one volume which you mount and that's where the data are supposed to be.
> Please, send the feedback here. Let me know if it fits your use cases and
> open tickets if you have some requests.
> Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170729/c06ac116/attachment.html>
