[GRASS-dev] GRASS flyer for the new osgeo branding
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Sat Jul 29 14:51:29 PDT 2017
Ciao Luca,
Nice work! I tried to contribute with suggestions directly in the svg, but my inkscape just messed things up. Therefore I simply attach text with suggestions (even if changes are not that visible that way).
Please feel free to reject or accept as you like…
I agree with Markus and Anna, that “old” has some negative connotation which I would avoid too.
I liked the “reliable number cruncher” branding in Markus FOSS4G 2015 presentation.
Furthermore, I would support Moritz suggestion to start with the important stuff and here I would put efficiency / robustness quite high (which I was missing a bit in the current text).
There is also the R interface (rgrass7) which is not mentioned in the “Interfaces” paragraph.
All this and some other small adjustments can be found in the attached txt.
Cheers
Stefan
From: grass-dev [mailto:grass-dev-bounces at lists.osgeo.org] On Behalf Of Markus Neteler
Sent: fredag 28. juli 2017 15.34
To: Anna Kratochvílová <kratochanna at gmail.com>
Cc: GRASS developers list <grass-dev at lists.osgeo.org>
Subject: Re: [GRASS-dev] GRASS flyer for the new osgeo branding
On Jul 28, 2017 3:27 PM, "Anna Petrášová" <kratochanna at gmail.com<mailto:kratochanna at gmail.com>> wrote:
> On Jul 28, 2017 8:09 AM, "Luca Delucchi" <lucadeluge at gmail.com<mailto:lucadeluge at gmail.com>> wrote:
>> On 27 July 2017 at 18:05, Anna Petrášová <kratochanna at gmail.com<mailto:kratochanna at gmail.com>> wrote:
>> sorry Anna I don't see the double GRASS is old, do you speak about "It
>> is the oldest and largest free" and "GRASS GIS was born more than 30
>> years ago"?
> Yes, that's what I meant, I don't think we should mention that GRASS is old twice.
I'd not use "old" at all.
It does not add anything positive in typical marketing bla.
IMHO better use long term or similar.
And thanks for working on it.
Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170729/cb1905c1/attachment-0001.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170729/cb1905c1/attachment-0001.txt>
