[GRASS-dev] [GRASS GIS] #3354: errors building re: grass/src/grass-7.2.1/lib/python/ctypes
GRASS GIS trac at osgeo.org
Thu Jun 1 14:44:36 PDT 2017
 Reporter:  saultdon   |      Owner:  grass-dev@…
     Type:  defect     |     Status:  new
 Priority:  normal     |  Milestone:
Component:  Compiling  |    Version:  7.2.1
 Keywords:             |        CPU:  x86-64
 Platform:  Linux      |
 Afternoon,
 I tried building 7.2.1 from the tar and am getting,
 GRASS GIS 7.2.1 exported compilation log
 Started compilation: Thu Jun  1 14:33:36 MST 2017
 Errors in:
 /tmp/makepkg/grass/src/grass-7.2.1/lib/python/ctypes
 In case of errors please change into the directory with error and run
 'make'.
 If you get multiple errors, you need to deal with them in the order they
 appear in the error log. If you get an error building a library, you will
 also get errors from anything which uses the library.
 So I did a `make` within that dir and get the following,
 make /tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-linux-
 gnu/etc/python/grass/lib
 make[1]: Entering directory
 '/tmp/makepkg/grass/src/grass-7.2.1/lib/python/ctypes'
 make[1]: '/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-linux-
 gnu/etc/python/grass/lib' is up to date.
 make[1]: Leaving directory
 make OBJ.x86_64-pc-linux-gnu/date.py OBJ.x86_64-pc-linux-gnu/gis.py
 OBJ.x86_64-pc-linux-gnu/raster.py OBJ.x86_64-pc-linux-gnu/gmath.py
 OBJ.x86_64-pc-linux-gnu/proj.py OBJ.x86_64-pc-linux-gnu/imagery.py
 OBJ.x86_64-pc-linux-gnu/vector.py OBJ.x86_64-pc-linux-gnu/rtree.py
 OBJ.x86_64-pc-linux-gnu/display.py OBJ.x86_64-pc-linux-gnu/stats.py
 OBJ.x86_64-pc-linux-gnu/dbmi.py OBJ.x86_64-pc-linux-gnu/raster3d.py
 OBJ.x86_64-pc-linux-gnu/arraystats.py OBJ.x86_64-pc-linux-gnu/cluster.py
 OBJ.x86_64-pc-linux-gnu/vedit.py OBJ.x86_64-pc-linux-gnu/segment.py
 OBJ.x86_64-pc-linux-gnu/rowio.py OBJ.x86_64-pc-linux-gnu/temporal.py
 OBJ.x86_64-pc-linux-gnu/ogsf.py OBJ.x86_64-pc-linux-gnu/nviz.py
 gnu/etc/python/grass/lib/date.py
 gnu/etc/python/grass/lib/gis.py
 gnu/etc/python/grass/lib/raster.py
 gnu/etc/python/grass/lib/gmath.py
 gnu/etc/python/grass/lib/proj.py
 gnu/etc/python/grass/lib/imagery.py
 gnu/etc/python/grass/lib/vector.py
 gnu/etc/python/grass/lib/rtree.py
 gnu/etc/python/grass/lib/display.py
 gnu/etc/python/grass/lib/stats.py
 gnu/etc/python/grass/lib/dbmi.py
 gnu/etc/python/grass/lib/raster3d.py
 gnu/etc/python/grass/lib/arraystats.py
 gnu/etc/python/grass/lib/cluster.py
 gnu/etc/python/grass/lib/vedit.py
 gnu/etc/python/grass/lib/segment.py
 gnu/etc/python/grass/lib/rowio.py
 gnu/etc/python/grass/lib/temporal.py
 gnu/etc/python/grass/lib/ogsf.py
 gnu/etc/python/grass/lib/nviz.py
 gnu/etc/python/grass/lib/__init__.py
 gnu/etc/python/grass/lib/ctypes_preamble.py
 gnu/etc/python/grass/lib/ctypes_loader.py
 gnu/etc/python/grass/lib/date.pyc
 gnu/etc/python/grass/lib/gis.pyc
 gnu/etc/python/grass/lib/raster.pyc
 gnu/etc/python/grass/lib/gmath.pyc
 gnu/etc/python/grass/lib/proj.pyc
 gnu/etc/python/grass/lib/imagery.pyc
 gnu/etc/python/grass/lib/vector.pyc
 gnu/etc/python/grass/lib/rtree.pyc
 gnu/etc/python/grass/lib/display.pyc
 gnu/etc/python/grass/lib/stats.pyc
 gnu/etc/python/grass/lib/dbmi.pyc
 gnu/etc/python/grass/lib/raster3d.pyc
 gnu/etc/python/grass/lib/arraystats.pyc
 gnu/etc/python/grass/lib/cluster.pyc
 gnu/etc/python/grass/lib/vedit.pyc
 gnu/etc/python/grass/lib/segment.pyc
 gnu/etc/python/grass/lib/rowio.pyc
 gnu/etc/python/grass/lib/temporal.pyc
 gnu/etc/python/grass/lib/ogsf.pyc
 gnu/etc/python/grass/lib/nviz.pyc
 gnu/etc/python/grass/lib/__init__.pyc
 gnu/etc/python/grass/lib/ctypes_preamble.pyc
 gnu/etc/python/grass/lib/ctypes_loader.pyc
 GISRC=/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-linux-
 gnu/demolocation/.grassrc72
 GISBASE=/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-linux-gnu
 PATH="/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-linux-
 gnu/bin:/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-linux-
 gnu/scripts:$PATH"
 PYTHONPATH="/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-linux-
 gnu/etc/python:/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-linux-
 gnu/gui/wxpython:$PYTHONPATH"
 LD_LIBRARY_PATH="/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-linux-
 gnu/scripts:/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-linux-
 gnu/lib:/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-linux-
 gnu/lib:.::/jre/lib" LC_ALL=C ./ctypesgen.py --cpp "gcc -E
 -D_FORTIFY_SOURCE=2      -I/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64
 -pc-linux-gnu/include -I/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-
 linux-gnu/include -D__GLIBC_HAVE_LONG_LONG" -lgrass_datetime.7.2.1
 gnu/include/grass/datetime.h
 gnu/include/grass/defs/datetime.h -o OBJ.x86_64-pc-linux-gnu/date.py
 Status: Preprocessing /tmp/tmpfcx1LI.h
 Status: gcc -E -D_FORTIFY_SOURCE=2
 -I/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-linux-gnu/include
 -D__GLIBC_HAVE_LONG_LONG -U __GNUC__ -dD "-Dinline=" "-D__inline__="
 "-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)="
 "-D__asm(x)=" "-DCTYPESGEN=1" /tmp/tmpfcx1LI.h
   File "./ctypesgen.py", line 139, in <module>
     descriptions = ctypesgencore.parser.parse(options.headers, options)
   File
 "/tmp/makepkg/grass/src/grass-7.2.1/lib/python/ctypes/ctypesgencore/parser/__init__.py",
 line 22, in parse
     parser.parse()
   File
 "/tmp/makepkg/grass/src/grass-7.2.1/lib/python/ctypes/ctypesgencore/parser/datacollectingparser.py",
 line 74, in parse
     ctypesparser.CtypesParser.parse(self, fname, None)
   File
 "/tmp/makepkg/grass/src/grass-7.2.1/lib/python/ctypes/ctypesgencore/parser/cparser.py",
 line 120, in parse
     self.preprocessor_parser.parse(filename)
   File
 "/tmp/makepkg/grass/src/grass-7.2.1/lib/python/ctypes/ctypesgencore/parser/preprocessor.py",
 line 218, in parse
     token = self.lexer.token()
   File
 line 63, in token
     result = lex.Lexer.token(self)
   File
 "/tmp/makepkg/grass/src/grass-7.2.1/lib/python/ctypes/ctypesgencore/parser/lex.py",
 line 355, in token
     newtok = func(tok)
   File
 "/tmp/makepkg/grass/src/grass-7.2.1/lib/python/ctypes/ctypesgencore/parser/pplexer.py",
 line 262, in t_ANY_int
     g1 = str(long(g1, 8))
 ValueError: invalid literal for long() with base 8:
 '08420217248550443400745280086994171'
 make[1]: *** [Makefile:102: OBJ.x86_64-pc-linux-gnu/date.py] Error 1
Ticket URL: <https://trac.osgeo.org/grass/ticket/3354>
