[GRASS-dev] [GRASS GIS] #3356: v.to.db: incorrect area calculations in lat-long location
trac at osgeo.org
Wed Jun 7 08:36:26 PDT 2017
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.0
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.to.db area lat-long
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:8 mmetz]:
> Replying to [comment:7 mmetz]:
> > Replying to [comment:6 mlennert]:
> > > Replying to [comment:5 annakrat]:
> > > > But the area computation problem must be somewhere in
[https://grass.osgeo.org/programming7
> > > >/area__poly1_8c.html#af6f1f53bacc34249be98006c95369695
G_ellipsoid_polygon_area], probably related
> > > > to very small numbers, but I couldn't pinpoint the problem. There
is something specific about this
> > > > polygon, when I draw a similar one, it gives more reasonable
results.
> > > So, yes, this definitely seems to be a precision issue, but at this
stage I can't really see where in the source code, and don't have much
time to delve into it in greater detail. Maybe MarkusM has an idea ?
> > The problem seems to be in G_ellipsoid_polygon_area() at
[https://trac.osgeo.org/grass/browser/grass/trunk/lib/gis/area_poly1.c#L161
L161]. If dy is much smaller than dx, dx / dy becomes very large and
erroneus values might sneak in. A simple solution could be to set dy to
zero if dy is very small, but then how to define "very small"?
Interestingly, dx must not be snapped to zero, otherwise I get complete
nonsense results for the test shapefile.
> Apparently small differences in latitudes of adjacent vertices can cause
a wrong latitude correction in G_ellipsoid_polygon_area(). Please try
trunk r71167.
> Note that this does not affect areas created with v.in.region, but this
fix also affects larger areas such as country boundaries.
Thanks for the quick find !
I tested and compared with the results of the R
[https://cran.r-project.org/package=geosphere geosphere] package (which
apparently uses [https://geographiclib.sourceforge.io/ GeographicLib]:
v.to.db poly -p op=area --q
1|0.126662200952979
In R:
crswgs84=CRS("+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs")
poly=readShapePoly("GRASS_area_problem/training_single.shp",proj4string=crswgs84,verbose=TRUE)
areaPolygon(poly)
[1] 0.1262853
Don't know if there are other "authoritative" programs to measure the area
of this polygon ? At one point, I guess it comes down to floating point
precision used in the different stages of the algorithm...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3356#comment:9>
