[GRASS-dev] v.kriging: ERREUR :Interpolating values is currently under maintenance (optimization).,
Eva Stopková
eva.stopkova at gmail.com
Thu Jun 8 12:46:09 PDT 2017
Moritz,
thank you for the notice. Today I submitted optimized v.kriging together
with the pdf file summarizing preliminary case studies (linked from the
manual).
I created the "maintenance mode", although this was not an optimal
strategy, to keep the version with native R-trees in the repository
(instead of previous version based on kd-trees from PCL library). I will
not branch them from now on.
Best regards,
Eva
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170608/7942a7f3/attachment.html>
