[GRASS-dev] [GRASS GIS] #3360: change "v.digit" to "g.gui.vdigit" in error message
trac at osgeo.org
Wed Jun 14 05:27:55 PDT 2017
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Vector | Version: svn-trunk
Keywords: | CPU: Unspecified
Platform: Unspecified |
related to [https://lists.osgeo.org/pipermail/grass-
dev/2017-June/085239.html dev ML]
"Vector digitizer not available
Reason: cannot import name GV_LINES
Note that the wxGUI's vector digitizer is currently disabled
(hopefully this will be fixed soon). Please keep an eye out
for updated versions of GRASS. In the meantime you can use
"v.digit" from the Develop Vector menu."
v.digit was changed to g.gui.vdigit; the error/warning message should
reflect this
Ticket URL: <https://trac.osgeo.org/grass/ticket/3360>
