[GRASS-dev] winGRASS: running several python modules in bat-files fails
Helmut Kudrnovsky hellik at web.de
Wed Jun 14 05:57:03 PDT 2017
>> v.db.addcolumn map=myreg2 columns="col1 inetger"
>typo in 'inetger'?
oh :-)
> how does it fail?
if you have several python modules listed in the bat file, only the first
one starts, the other aren't invoked.
the reason may be: in winGRASS the python scripts are invoked by bat-file
wrapper; if the first python module is started, it changes to the e.g.
v.db.addtable.bat, invokes the python script, but then it doesnt't come back
to test.bat, therefore the next python module in the list isn't started.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/winGRASS-running-several-python-modules-in-bat-files-fails-tp5324173p5324181.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
