[GRASS-dev] [GRASS GIS] #3331: ctypes: ValueError: invalid literal for int() with base 8: '08420217248550443400745280086994171'
trac at osgeo.org
Wed Jun 14 21:36:40 PDT 2017
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Python | Version: svn-releasebranch72
Resolution: | Keywords: ctypes, python
CPU: Unspecified | Platform: Unspecified
Comment (by neteler):
Replying to [comment:15 annakrat]:
> Replying to [comment:12 neteler]:
> > In r71180 I have now removed the -dD flag in
ctypesgencore/preprocessor because it is failing with gcc7 and apparently
not causing any harm with gcc6.
> > To be backported once sufficiently tested.
> Seems to break parts of WxGUI using ctypes - vector digitizer and 3d
view - on Ubuntu and MS Windows.
Would it be possible to isolate the breakage with a small code example?
Otherwise debugging the ctypes lexer and bindings is quite hard.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3331#comment:16>
