[GRASS-dev] [GRASS GIS] #517: v.net.iso / v.net.alloc: keep original cat values or change output to field in attribute table instead of new map
trac at osgeo.org
Tue Jun 20 02:56:42 PDT 2017
Reporter: effilc36 | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: minor | Milestone: 7.4.0
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.net.iso
CPU: All | Platform: All
Comment (by mmetz):
Replying to [comment:10 mlennert]:
> Replying to [comment:9 mmetz]:
> > Replying to [comment:8 mlennert]:
> > > Pinging this after a class where many students thought they did
something wrong because the approach using cat values is not very
intuitive and is not directly visible.
> > > I still think that giving the option to write the results as new
columns in the attribute file of the network would be a nice feature to
have.
> > v.net.iso and v.net.alloc split some of the input lines: if the start
node and the end node of a line belong to different classes, that line is
split proportional to the cost difference and the two (or more) new lines
will belong to different classes.
> > Therefore it is not possible to simply add a new attribute to input
lines.
> Now that you say it, it's obvious... ;-)
> > What could be done is to add a new flag that 1) creates unique
categories and adds an attribute table with class id (iso zone) and
distance, 2) copies original arc attributes to a separate layer with some
lines sharing the original arc category.
> That sounds like a good idea.
Done in r71193 for v.net.iso (new flag -u). The newly created attribute
table has the fields cat (category value), ocat (original category value),
center (category value of nearest center), isonr (iso band number), isolbl
(iso band label). A side effect is that a line is now correctly split if
it is assigned to two different centers.
Done in r71194 for v.net.alloc (new flag -u). The newly created attribute
center (category value of nearest center).
> And any objection to applying in any case a default color table ? I know
(think) this would be a first, but for these modules one has to already
understand GRASS' category vs attributes logic in order to understand the
results. Coloring them by default would make the user experience easier,
IMHO. Or at least give this option a an additional flag ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/517#comment:11>
