[GRASS-dev] [GRASS GIS] #3331: ctypes: ValueError: invalid literal for int() with base 8: '08420217248550443400745280086994171'
trac at osgeo.org
Thu Jun 22 06:28:59 PDT 2017
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Python | Version: svn-releasebranch72
Resolution: | Keywords: ctypes, python
CPU: Unspecified | Platform: Unspecified
Comment (by hellik):
Replying to [comment:36 neteler]:
> Remains how to deal with the gcc7 ctpes lexer problem. At time both
floats1.diff and floats2.diff are added to trunk, perhaps only one should
be used? Hints welcome.
windows builds are broken in grass_trunk/lib/python/ctypes
[https://wingrass.fsv.cvut.cz/grass73/x86_64/logs/log-r71204-275/error.log
error log]
GRASS GIS 7.3.svn r71204 compilation log
Started compilation: Wed Jun 21 21:28:48 2017
Errors in:
/c/msys64/usr/src/grass_trunk/lib/python/ctypes
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Wed Jun 21 22:01:28 2017
Ticket URL: <https://trac.osgeo.org/grass/ticket/3331#comment:37>
