[GRASS-dev] [GRASS GIS] #517: v.net.iso / v.net.alloc: keep original cat values or change output to field in attribute table instead of new map
trac at osgeo.org
Mon Jun 26 08:22:38 PDT 2017
Reporter: effilc36 | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: minor | Milestone: 7.4.0
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.net.iso
CPU: All | Platform: All
Comment (by mlennert):
Replying to [comment:14 mmetz]:
> Replying to [comment:13 mmetz]:
> > I want to sync v.net.alloc and v.net.iso some more, these two modules
are very similar.
> Done in trunk r71212.
> v.net.iso could now with little effort changed to optionally produce the
output of v.net.alloc. v.net.alloc could then become a simple wrapper for
v.net.iso.
I just tested and both work fine in the current state.
Is it better to have everything in a module and create wrapper modules, or
would it be more interesting to put the common part of the code into a
library ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/517#comment:15>
