[GRASS-dev] [GRASS GIS] #2942: Startup after Novice Install
GRASS GIS trac at osgeo.org
Mon Jun 26 13:30:58 PDT 2017
  Reporter:  pactriglo  |      Owner:  grass-dev@…
      Type:  defect     |     Status:  new
  Priority:  normal     |  Milestone:  7.0.6
 Component:  Startup    |    Version:  7.0.3
Resolution:             |   Keywords:
       CPU:  OSX/Intel  |   Platform:  MacOSX
Description changed by neteler:
Old description:
> Last login: Sun Feb 28 19:57:43 on ttys000
> BenjamiillosMBP:~ benjaminpezzillo$
> '/Applications/GRASS-7.0.app/Contents/MacOS/grass.sh'; exit
> Rebuilding Addon HTML manual pages index...
> Rebuilding Addon menu...
> Python 2.7.10 found.
> Starting GRASS GIS...
> dyld: Library not loaded: /usr/local/lib/libintl.8.dylib
>   Referenced from:
> /Applications/GRASS-7.0.app/Contents/MacOS/lib/libgrass_gis.7.0.3.dylib
>   Reason: image not found
> Traceback (most recent call last):
>   File
> "/Applications/GRASS-7.0.app/Contents/MacOS/gui/wxpython/gis_set.py",
> line 31, in <module>
>     from core import globalvar
>   File
> "/Applications/GRASS-7.0.app/Contents/MacOS/gui/wxpython/core/globalvar.py",
> line 29, in <module>
>     from core.debug import Debug
>   File
> "/Applications/GRASS-7.0.app/Contents/MacOS/gui/wxpython/core/debug.py",
> line 66, in <module>
>     Debug = DebugMsg()
>   File
> line 37, in __init__
>     self.SetLevel()
>   File
> line 42, in SetLevel
>     self.debuglevel = int(grass.gisenv().get('WX_DEBUG', 0))
>   File
> "/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/script/core.py",
> line 934, in gisenv
>     s = read_command("g.gisenv", flags='n')
>   File
> line 442, in read_command
>     process = pipe_command(*args, **kwargs)
>   File
> line 417, in pipe_command
>     return start_command(*args, **kwargs)
>   File
> line 355, in start_command
>     if debug_level() > 0:
>   File
> line 1517, in debug_level
>     _debug_level = int(gisenv().get('DEBUG', 0))
>   File
> line 934, in gisenv
>   File
> line 445, in read_command
>     return handle_errors(returncode, stdout, args, kwargs)
>   File
> line 312, in handle_errors
>     returncode=returncode)
> grass.exceptions.CalledModuleError: Module run None ['g.gisenv', '-n']
> ended with error
> Process ended with non-zero return code -5. See errors in the (error)
> output.
> Error in GUI startup. If necessary, please report this error to the GRASS
> developers.
> Switching to text mode now.
> Hit RETURN to continue...
>   File "/Applications/GRASS-7.0.app/Contents/MacOS/grass70", line 1438,
> in <module>
>     set_data()
>   File "/Applications/GRASS-7.0.app/Contents/MacOS/grass70", line 681, in
> set_data
>     gui_startup(grass_gui == 'gtext')
>   File "/Applications/GRASS-7.0.app/Contents/MacOS/grass70", line 703, in
> gui_startup
>     os.execlp(cmd_name, "-text")
>   File
> "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/os.py",
> line 329, in execlp
>     execvp(file, args)
>   File
> line 346, in execvp
>     _execvpe(file, args)
>   File
> line 382, in _execvpe
>     func(fullname, *argrest)
> OSError: [Errno 2] No such file or directory
> logout
> Saving session...
> ...copying shared history...
> ...saving history...truncating history files...
> ...completed.
> [Process completed]
New description:
   Referenced from:
   File
 "/Applications/GRASS-7.0.app/Contents/MacOS/gui/wxpython/gis_set.py", line
 31, in <module>
   File
   File
     Debug = DebugMsg()
   File
     self.SetLevel()
   File
   File
 line 934, in gisenv
   File
   File
   File
   File
   File
 line 934, in gisenv
   File
   File
 ended with error
 output.
 developers.
   File "/Applications/GRASS-7.0.app/Contents/MacOS/grass70", line 1438, in
 <module>
     set_data()
 set_data
 gui_startup
   File
 line 329, in execlp
     execvp(file, args)
   File
 line 346, in execvp
   File
 logout
 Saving session...
 ...completed.
 [Process completed]
Ticket URL: <https://trac.osgeo.org/grass/ticket/2942#comment:3>
