[GRASS-dev] [GRASS GIS] #3302: t.rast.algebra: add support for suffix option in output map names
GRASS GIS trac at osgeo.org
Wed Mar 1 00:05:40 PST 2017
 Reporter:  veroandreo                           |      Owner:  grass-dev@…
     Type:  enhancement                          |     Status:  new
 Priority:  normal                               |  Milestone:  7.4.0
Component:  Temporal                             |    Version:  svn-trunk
 Keywords:  t.rast.algebra, t.rast.mapcalc,      |        CPU:  Unspecified
  suffix                                         |
 Platform:  Unspecified                          |
 Currently, G7:t.rast.algebra uses "basename_n" (n=1,2,3...number of maps
 in the strds) as naming scheme for output maps. This makes it a bit
 difficult to sort them afterwards (#2736), particularly, when one runs
 some processing not in the temporal framework on them (hence, the output
 maps are not registered into a strds).
 It would be great to also have suffix parameter in t.rast.algebra as well
 as G7:t.rast.mapcalc, as it is already in G7:t.rast.aggregate with the
 possibility to have granularity, time or numerical suffix (with zero
 padding). There are comments on this issue in #2294, but the ticket was
 for t.rast.aggregate.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3302>
