[GRASS-dev] [GRASS-SVN] r70710 - in grass/branches/releasebranch_7_2: lib/vector/vedit raster/r.timestamp raster/r.to.vect raster/r.topidx raster/r.topmodel scripts/v.db.addtable vector/v.build.polylines vector/v.distance vector/v.edit vector/v.patch vector/v.select vector/v.to.db vector/v.to.points vector/v.what
Martin Landa landa.martin at gmail.com
Wed Mar 1 04:51:06 PST 2017
2017-03-01 13:31 GMT+01:00 Martin Landa <landa.martin at gmail.com>:
> please  *explain* your changes in log message next time. It's
> flustrating for those who are preparing news page about release to dig
> into such commits. Log message should help to understand what is
> purpose of the commit.
Also spliting such huge commit into small commits would be good idea. Ma
>>    grass/branches/releasebranch_7_2/raster/r.to.vect/areas_io.c
>>    grass/branches/releasebranch_7_2/raster/r.to.vect/global.h
>>    grass/branches/releasebranch_7_2/raster/r.to.vect/main.c
>>    grass/branches/releasebranch_7_2/raster/r.topidx/r.topidx.html
>>    grass/branches/releasebranch_7_2/raster/r.topmodel/r.topmodel.html
>>    grass/branches/releasebranch_7_2/scripts/v.db.addtable/v.db.addtable.py
>>    grass/branches/releasebranch_7_2/vector/v.build.polylines/main.c
>>    grass/branches/releasebranch_7_2/vector/v.build.polylines/walk.c
>>    grass/branches/releasebranch_7_2/vector/v.distance/main.c
>>    grass/branches/releasebranch_7_2/vector/v.distance/v.distance.html
>>    grass/branches/releasebranch_7_2/vector/v.edit/main.c
>>    grass/branches/releasebranch_7_2/vector/v.edit/max_distance.c
>>    grass/branches/releasebranch_7_2/vector/v.patch/main.c
>>    grass/branches/releasebranch_7_2/vector/v.select/copy_tabs.c
>>    grass/branches/releasebranch_7_2/vector/v.select/main.c
>>    grass/branches/releasebranch_7_2/vector/v.to.db/main.c
>>    grass/branches/releasebranch_7_2/vector/v.to.points/write.c
>>    grass/branches/releasebranch_7_2/vector/v.what/main.c
>> Log:
>> Backport r70666, r70637, r70636, r70635, r70634, r70633, r70706, r70707, r70708, r70611, r70612, r70613, r70614, r70599, r70589, r70586, r70582, r70537, r70509, r70506, r70709, r70507, r69139
>> Modified: grass/branches/releasebranch_7_2/lib/vector/vedit/break.c
>> --- grass/branches/releasebranch_7_2/lib/vector/vedit/break.c   2017-03-01 11:35:50 UTC (rev 70709)
>> +++ grass/branches/releasebranch_7_2/lib/vector/vedit/break.c   2017-03-01 11:45:44 UTC (rev 70710)
>> @@ -247,12 +247,13 @@
>>         line_new = -1;
>>      if (line_new > -1) {
>> +       n_points = Points_from->n_points - 1;
>>         if (first) {
>>             x = Points_from->x[0];
>>             y = Points_from->y[0];
>>         else {
>> -           n_points = Points_from->n_points - 1;
>>             x = Points_from->x[n_points];
>>             y = Points_from->y[n_points];
>> Modified: grass/branches/releasebranch_7_2/lib/vector/vedit/move.c
>> --- grass/branches/releasebranch_7_2/lib/vector/vedit/move.c    2017-03-01 11:35:50 UTC (rev 70709)
>> +++ grass/branches/releasebranch_7_2/lib/vector/vedit/move.c    2017-03-01 11:45:44 UTC (rev 70710)
>> @@ -71,7 +71,7 @@
>>                     for (bgi = 0; bgi < nbgmaps; bgi++) {
>>                         if (Vedit_snap_point
>> -                           (BgMap[bgi], line, &x[j], &y[j], &z[j], thresh,
>> +                           (BgMap[bgi], -1, &x[j], &y[j], &z[j], thresh,
>>                              (snap == SNAPVERTEX) ? 1 : 0))
>>                             break;      /* snapped, don't continue */
>> Modified: grass/branches/releasebranch_7_2/lib/vector/vedit/vertex.c
>> --- grass/branches/releasebranch_7_2/lib/vector/vedit/vertex.c  2017-03-01 11:35:50 UTC (rev 70709)
>> +++ grass/branches/releasebranch_7_2/lib/vector/vedit/vertex.c  2017-03-01 11:45:44 UTC (rev 70710)
>> @@ -115,7 +115,7 @@
>> -                                       (BgMap[bgi], line, &x[k], &y[k],
>> +                                       (BgMap[bgi], -1, &x[k], &y[k],
>>                                          &z[k], thresh_snap,
>>                                         moved[k] = 2;
>> Modified: grass/branches/releasebranch_7_2/raster/r.timestamp/r.timestamp.html
>> --- grass/branches/releasebranch_7_2/raster/r.timestamp/r.timestamp.html        2017-03-01 11:35:50 UTC (rev 70709)
>> +++ grass/branches/releasebranch_7_2/raster/r.timestamp/r.timestamp.html        2017-03-01 11:45:44 UTC (rev 70710)
>> @@ -15,7 +15,7 @@
>>  The timestamp values must use the format as described in the <em>GRASS
>>  Datetime Library</em>. The source tree for this library should have a
>> -description of the format. For convience, the formats are reproduced
>> +description of the format. For convenience, the formats are reproduced
>>  here:
>>  <p>There are two types of datetime values:
>> Modified: grass/branches/releasebranch_7_2/raster/r.to.vect/areas_io.c
>> --- grass/branches/releasebranch_7_2/raster/r.to.vect/areas_io.c        2017-03-01 11:35:50 UTC (rev 70709)
>> +++ grass/branches/releasebranch_7_2/raster/r.to.vect/areas_io.c        2017-03-01 11:45:44 UTC (rev 70710)
>> @@ -34,7 +34,7 @@
>>  int write_boundary(struct COOR *seed)
>>      struct COOR *point, *line_begin, *line_end, *last;
>> -    int dir, line_type, n, n1, i;
>> +    int dir, line_type, n, n1;
>>      point = seed;
>>      if ((dir = at_end(point))) {       /* already have one end of line */
>> Modified: grass/branches/releasebranch_7_2/raster/r.to.vect/global.h
>> --- grass/branches/releasebranch_7_2/raster/r.to.vect/global.h  2017-03-01 11:35:50 UTC (rev 70709)
>> +++ grass/branches/releasebranch_7_2/raster/r.to.vect/global.h  2017-03-01 11:45:44 UTC (rev 70710)
>> @@ -104,7 +104,7 @@
>>  int extract_lines(void);
>>  /* lines_io.c */
>> -int write_line(struct COOR *seed);
>> +int write_line(struct COOR *);
>>  /* areas.c */
>>  int alloc_areas_bufs(int);
>> @@ -112,7 +112,7 @@
>>  int more_equivs(void);
>>  /* areas_io.c */
>> -int write_boundary(struct COOR *seed);
>> +int write_boundary(struct COOR *);
>>  int write_area(struct area_table *, struct equiv_table *, int, int);
>>  /* points.c */
>> @@ -124,4 +124,7 @@
>>  int at_end(struct COOR *);
>>  int read_row(void *);
>>  void insert_value(int, int, double);
>> -int free_ptr(struct COOR *ptr);
>> +int free_ptr(struct COOR *);
>> +/* set_error_handler.c */
>> +void set_error_handler(struct Map_info *, dbDriver **);
>> Modified: grass/branches/releasebranch_7_2/raster/r.to.vect/main.c
>> --- grass/branches/releasebranch_7_2/raster/r.to.vect/main.c    2017-03-01 11:35:50 UTC (rev 70709)
>> +++ grass/branches/releasebranch_7_2/raster/r.to.vect/main.c    2017-03-01 11:45:44 UTC (rev 70710)
>> @@ -8,7 +8,7 @@
>>   * PURPOSE:      Converts a raster map into a vector map layer
>> - * COPYRIGHT:    (C) 2007, 2011 by the GRASS Development Team
>> + * COPYRIGHT:    (C) 2007, 2011, 2017 by the GRASS Development Team
>>   *               This program is free software under the GNU General Public
>>   *               License (>=v2). Read the file COPYING that comes with GRASS
>> @@ -151,10 +151,11 @@
>>         G_warning(_("Categories will be unique sequence, raster values will be lost."));
>> +    set_error_handler(&Map, &driver);
>>      if (Vect_open_new(&Map, out_opt->answer, z_flg->answer) < 0)
>>         G_fatal_error(_("Unable to create vector map <%s>"), out_opt->answer);
>> -    Vect_set_error_handler_io(NULL, &Map);
>>      Vect_hist_command(&Map);
>>      Cats = Vect_new_cats_struct();
>> @@ -186,7 +187,6 @@
>>         if (driver == NULL)
>>             G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
>>                           Fi->database, Fi->driver);
>> -        db_set_error_handler_driver(driver);
>>         /* Create new table */
>>         db_zero_string(&sql);
>> Added: grass/branches/releasebranch_7_2/raster/r.to.vect/set_error_handler.c
>> --- grass/branches/releasebranch_7_2/raster/r.to.vect/set_error_handler.c                               (rev 0)
>> +++ grass/branches/releasebranch_7_2/raster/r.to.vect/set_error_handler.c       2017-03-01 11:45:44 UTC (rev 70710)
>> @@ -0,0 +1,33 @@
>> +#include <grass/gis.h>
>> +#include <grass/vector.h>
>> +struct handler_input
>> +    struct Map_info *Map;
>> +    dbDriver **driver;
>> +static void error_handler(void *p)
>> +    const struct handler_input *input = (const struct handler_input *)p;
>> +    if (input->driver && *input->driver)
>> +       db_close_database_shutdown_driver(*input->driver);
>> +    if (input->Map) {
>> +       char *name = G_store(input->Map->name);
>> +       if (input->Map->open == VECT_OPEN_CODE)
>> +           Vect_close(input->Map);
>> +       Vect_delete(name);
>> +       G_free(name);
>> +void set_error_handler(struct Map_info *Map, dbDriver **driver)
>> +    struct handler_input *input = G_malloc(sizeof(struct handler_input));
>> +    input->Map = Map;
>> +    input->driver = driver;
>> +    G_add_error_handler(error_handler, input);
>> Modified: grass/branches/releasebranch_7_2/raster/r.topidx/r.topidx.html
>> --- grass/branches/releasebranch_7_2/raster/r.topidx/r.topidx.html      2017-03-01 11:35:50 UTC (rev 70709)
>> +++ grass/branches/releasebranch_7_2/raster/r.topidx/r.topidx.html      2017-03-01 11:45:44 UTC (rev 70710)
>> @@ -23,7 +23,7 @@
>>  <a href="r.mapcalc.html">r.mapcalc</a>
>>  </em>
>>  <br>
>> -<a href="http://idea.isnew.info/r.topidx">Known issues</a>
>> +<a href="http://idea.isnew.info/r.topidx.html">Known issues</a>
>>  <h2>REFERENCES</h2>
>> Modified: grass/branches/releasebranch_7_2/raster/r.topmodel/r.topmodel.html
>> --- grass/branches/releasebranch_7_2/raster/r.topmodel/r.topmodel.html  2017-03-01 11:35:50 UTC (rev 70709)
>> +++ grass/branches/releasebranch_7_2/raster/r.topmodel/r.topmodel.html  2017-03-01 11:45:44 UTC (rev 70710)
>> @@ -152,7 +152,7 @@
>>  <a href="r.topidx.html">r.topidx</a>
>>  </em>
>>  <br>
>> -<a href="http://idea.isnew.info/r.topmodel">How to run r.topmodel</a>
>> +<a href="http://idea.isnew.info/r.topmodel.html">How to run r.topmodel</a>
>>  <h2>AUTHORS</h2>
>> Modified: grass/branches/releasebranch_7_2/scripts/v.db.addtable/v.db.addtable.py
>> --- grass/branches/releasebranch_7_2/scripts/v.db.addtable/v.db.addtable.py     2017-03-01 11:35:50 UTC (rev 70709)
>> +++ grass/branches/releasebranch_7_2/scripts/v.db.addtable/v.db.addtable.py     2017-03-01 11:45:44 UTC (rev 70710)
>> @@ -86,7 +86,7 @@
>>          grass.verbose(_("Using user specified table name: %s") % table)
>>      # check if DB parameters are set, and if not set them.
>> -    grass.run_command('db.connect', flags='c')
>> +    grass.run_command('db.connect', flags='c', quiet=True)
>>      grass.verbose(_("Creating new DB connection based on default mapset settings..."))
>>      kv = grass.db_connection()
>>      database = kv['database']
>> @@ -106,15 +106,21 @@
>>                                  stderr=nuldev)
>>      if not table in tables.splitlines():
>> +        colnames = []
>>          if columns:
>> -            column_def = [x.strip().lower() for x in columns.strip().split(',')]
>> +            column_def = []
>> +            for x in ' '.join(columns.lower().split()).split(','):
>> +                colname = x.split()[0]
>> +                if colname in colnames:
>> +                    grass.fatal(_("Duplicate column name '%s' not allowed") % colname)
>> +                colnames.append(colname)
>> +                column_def.append(x)
>>          else:
>>              column_def = []
>>          # if not existing, create it:
>> -        column_def_key = "%s integer" % key
>> -        if column_def_key not in column_def:
>> -            column_def.insert(0, column_def_key)
>> +        if not key in colnames:
>> +            column_def.insert(0, "%s integer" % key)
>>          column_def = ','.join(column_def)
>>          grass.verbose(_("Creating table with columns (%s)...") % column_def)
>> @@ -133,10 +139,17 @@
>>                        map=map_name, database=database, driver=driver,
>>                        layer=layer, table=table, key=key)
>> -    # finally we have to add cats into the attribute DB to make modules such as v.what.rast happy:
>> -    # (creates new row for each vector line):
>> -    grass.run_command('v.to.db', map=map_name, layer=layer,
>> -                      option='cat', column=key, qlayer=layer)
>> +    # finally we have to add cats into the attribute DB to make
>> +    # modules such as v.what.rast happy: (creates new row for each
>> +    # vector line):
>> +    try:
>> +        grass.run_command('v.to.db', map=map_name, layer=layer,
>> +                          option='cat', column=key, qlayer=layer)
>> +    except CalledModuleError:
>> +        # remove link
>> +        grass.run_command('v.db.connect', quiet=True, flags='d',
>> +                          map=map_name, layer=layer)
>> +        return 1
>>      grass.verbose(_("Current attribute table links:"))
>>      if grass.verbosity() > 2:
>> Modified: grass/branches/releasebranch_7_2/vector/v.build.polylines/main.c
>> --- grass/branches/releasebranch_7_2/vector/v.build.polylines/main.c    2017-03-01 11:35:50 UTC (rev 70709)
>> +++ grass/branches/releasebranch_7_2/vector/v.build.polylines/main.c    2017-03-01 11:45:44 UTC (rev 70710)
>> @@ -97,7 +97,6 @@
>>      int polyline;
>>      int *lines_visited;
>> -    int points_in_polyline;
>>      int start_line;
>>      int nlines;
>>      int write_cats, copy_tables;
>> @@ -177,8 +176,10 @@
>>         write_cats = NO_CATS;
>>      else if (strcmp(cats->answer, "first") == 0)
>>         write_cats = ONE_CAT;
>> -    else
>> +    else if (strcmp(cats->answer, "multi") == 0)
>>         write_cats = MULTI_CATS;
>> +    else
>> +       write_cats = SAME_CATS;
>>      if (type_opt->answer)
>>         type = Vect_option_to_types(type_opt);
>> @@ -218,9 +219,8 @@
>>         G_debug(1, "Polyline %d: start line = %d", polyline, start_line);
>>         /* Walk forward and pick up coordinates */
>> -       points_in_polyline =
>> -           walk_forward_and_pick_up_coords(&map, start_line, ltype, points,
>> -                                           lines_visited, Cats, write_cats);
>> +       walk_forward_and_pick_up_coords(&map, start_line, ltype, points,
>> +                                       lines_visited, Cats, write_cats);
>>         /* Write the line (type of the first line is used) */
>>         Vect_write_line(&Out, ltype, points, Cats);
>> @@ -230,12 +230,10 @@
>>      G_verbose_message(n_("%d line or boundaries found in input vector map",
>>                           "%d lines or boundaries found in input vector map",
>> -                         nlines),
>> -                     nlines, Vect_get_name(&map), Vect_get_mapset(&map));
>> +                         nlines), nlines);
>>      G_verbose_message(n_("%d polyline stored in output vector map",
>>                           "%d polylines stored in output vector map",
>> -                         polyline),
>> -                     polyline, Vect_get_name(&Out), Vect_get_mapset(&Out));
>> +                         polyline), polyline);
>>      /* Copy (all linked) tables if needed */
>>      if (copy_tables) {
>> Modified: grass/branches/releasebranch_7_2/vector/v.build.polylines/walk.c
>> --- grass/branches/releasebranch_7_2/vector/v.build.polylines/walk.c    2017-03-01 11:35:50 UTC (rev 70709)
>> +++ grass/branches/releasebranch_7_2/vector/v.build.polylines/walk.c    2017-03-01 11:45:44 UTC (rev 70710)
>> @@ -129,7 +129,7 @@
>>      int cat_idx;
>>      int line, next_line, n1, n2;
>> -    int type, node, next_node;
>> +    int node, next_node;
>>      struct line_pnts *pnts;
>>      struct line_cats *cats_tmp;
>> @@ -149,9 +149,9 @@
>>      /* Pick up first set of coordinates */
>>      lines_visited[line] = 1;
>>      if (cats_tmp)
>> -       type = Vect_read_line(map, pnts, Cats, line);
>> +       Vect_read_line(map, pnts, Cats, line);
>>      else
>> -       type = Vect_read_line(map, pnts, NULL, line);
>> +       Vect_read_line(map, pnts, NULL, line);
>>      Vect_get_line_nodes(map, line, &n1, &n2);
>>      next_line = find_next_line(map, line, n1, ltype);
>> @@ -175,7 +175,7 @@
>>      node = next_node;
>>      while (line != 0 && line != start_line) {
>>         G_debug(2, "  line = %d", line);
>> -       type = Vect_read_line(map, pnts, cats_tmp, line);
>> +       Vect_read_line(map, pnts, cats_tmp, line);
>>         if (cats_tmp && write_cats == MULTI_CATS) {
>>             for (cat_idx = 0; cat_idx < cats_tmp->n_cats; cat_idx++) {
>>                 Vect_cat_set(Cats, cats_tmp->field[cat_idx],
>> Modified: grass/branches/releasebranch_7_2/vector/v.distance/main.c
>> --- grass/branches/releasebranch_7_2/vector/v.distance/main.c   2017-03-01 11:35:50 UTC (rev 70709)
>> +++ grass/branches/releasebranch_7_2/vector/v.distance/main.c   2017-03-01 11:45:44 UTC (rev 70710)
>> @@ -286,6 +286,10 @@
>>             Upload[i].upload = TO_ATTR;
>> +       /* store default column names if column= is not given */
>> +       if (!opt.column->answer)
>> +           Upload[i].column = G_store(opt.upload->answers[i]);
>>         i++;
>>      Upload[i].upload = END;
>> @@ -625,8 +629,12 @@
>>      /* Go through all lines in 'from' and find nearest in 'to' for each */
>> -    /* Note: as from_type is restricted to GV_POINTS (for now) everything is simple */
>> +    /* Note: as from_type is restricted to GV_POINTS (for now) everything is
>> +     * simple */
>> +    /* suppress compiler warnings */
>> +    tx = ty = tz = fx = fy = fz = 0;
>>      count = 0;                 /* count of distances in 'do_all' mode */
>>      /* Find nearest features for 'from' lines */
>>      if (nfromlines) {
>> @@ -1388,7 +1396,7 @@
>>             G_percent(i, count, 1);
>>         /* Write line connecting nearest points */
>> -       if (Outp != NULL) {
>> +       if (Near[i].count > 0 && Outp != NULL) {
>>             Vect_reset_line(FPoints);
>>             Vect_reset_cats(FCats);
>> Modified: grass/branches/releasebranch_7_2/vector/v.distance/v.distance.html
>> --- grass/branches/releasebranch_7_2/vector/v.distance/v.distance.html  2017-03-01 11:35:50 UTC (rev 70709)
>> +++ grass/branches/releasebranch_7_2/vector/v.distance/v.distance.html  2017-03-01 11:45:44 UTC (rev 70710)
>> @@ -97,7 +97,7 @@
>>  needed for network analysis:
>>  <div class="code"><pre>
>> -v.distance -p from=pnt to=ln out=connections upload=dist column=dist
>> +v.distance from=pnt to=ln out=connections upload=dist column=dist
>>  </pre></div>
>>  <h3>Query information</h3>
>> @@ -116,7 +116,7 @@
>>  Find nearest features:
>> -v.distance from=pnt to=map_to_query upload=cat col=somecol -p
>> +v.distance -p from=pnt to=map_to_query upload=cat
>>  </pre></div>
>>  <h3>Point-in-polygon</h3>
>> @@ -174,7 +174,7 @@
>>  echo "0|-58|1" | v.in.ascii output=pnt2 input=-
>>  # here, distances is in degree units
>> -v.distance from=pnt1 to=pnt2 upload=dist col=distance -p --q
>> +v.distance -p --q from=pnt1 to=pnt2 upload=dist
>>  from_cat|distance
>>  1|3
>>  </pre></div>
>> @@ -186,15 +186,14 @@
>>  <p>
>>  Spearfish sample data location:
>> -v.distance -pa from=archsites to=archsites upload=dist col=dist
>> +v.distance -pa from=archsites to=archsites upload=dist
>>  </pre></div>
>>  <p>
>>  North Carolina sample data location:
>> -v.distance -pa from=hospitals to=hospitals upload=dist \
>> -  col=dist separator=comma
>> +v.distance -pa from=hospitals to=hospitals upload=dist separator=tab
>>  from_cat to_cat       dist
>>                1          2          3          4          5 ...
>>  1             0    7489.10  339112.17   70900.39   70406.23 ...
>> Modified: grass/branches/releasebranch_7_2/vector/v.edit/main.c
>> --- grass/branches/releasebranch_7_2/vector/v.edit/main.c       2017-03-01 11:35:50 UTC (rev 70709)
>> +++ grass/branches/releasebranch_7_2/vector/v.edit/main.c       2017-03-01 11:45:44 UTC (rev 70710)
>> @@ -8,7 +8,7 @@
>>   *             Jachym Cepicky
>>   *             Major updates by Martin Landa <landa.martin gmail.com>
>> - * COPYRIGHT:  (C) 2006-2014 by the GRASS Development Team
>> + * COPYRIGHT:  (C) 2006-2017 by the GRASS Development Team
>>   *             Public License (>=v2). Read the file COPYING that comes
>> Modified: grass/branches/releasebranch_7_2/vector/v.edit/max_distance.c
>> --- grass/branches/releasebranch_7_2/vector/v.edit/max_distance.c       2017-03-01 11:35:50 UTC (rev 70709)
>> +++ grass/branches/releasebranch_7_2/vector/v.edit/max_distance.c       2017-03-01 11:45:44 UTC (rev 70710)
>> @@ -39,6 +39,8 @@
>>      if (maxdistance < 0.0) {
>>         G_get_window(&window);
>> +       G_begin_distance_calculations();
>>         ew_dist1 =
>>             G_distance(window.east, window.north, window.west, window.north);
>>         /* EW Dist at South Edge */
>> Modified: grass/branches/releasebranch_7_2/vector/v.patch/main.c
>> --- grass/branches/releasebranch_7_2/vector/v.patch/main.c      2017-03-01 11:35:50 UTC (rev 70709)
>> +++ grass/branches/releasebranch_7_2/vector/v.patch/main.c      2017-03-01 11:45:44 UTC (rev 70710)
>> @@ -413,8 +413,11 @@
>>      Vect_set_map_name(&OutMap, "Output from v.patch");
>>      Vect_set_person(&OutMap, G_whoami());
>> -    if (!no_topo->answer)
>> +    if (!no_topo->answer) {
>> +       if (append->answer)
>> +           Vect_build_partial(&OutMap, GV_BUILD_NONE);
>>         Vect_build(&OutMap);
>>      Vect_close(&OutMap);
>>      if (bbox_name) {
>> Modified: grass/branches/releasebranch_7_2/vector/v.select/copy_tabs.c
>> --- grass/branches/releasebranch_7_2/vector/v.select/copy_tabs.c        2017-03-01 11:35:50 UTC (rev 70709)
>> +++ grass/branches/releasebranch_7_2/vector/v.select/copy_tabs.c        2017-03-01 11:45:44 UTC (rev 70710)
>> @@ -55,12 +55,17 @@
>>         OFi =
>>             Vect_default_field_info(Out, IFi->number, IFi->name, ttype);
>> -       ret =
>> -           db_copy_table_by_ints(IFi->driver, IFi->database, IFi->table,
>> -                                 OFi->driver,
>> -                                 Vect_subst_var(OFi->database, Out),
>> -                                 OFi->table, IFi->key, cats[i],
>> -                                 ncats[i]);
>> +       if (ncats[i] > 0)
>> +           ret = db_copy_table_by_ints(IFi->driver, IFi->database, IFi->table,
>> +                                       OFi->driver,
>> +                                       Vect_subst_var(OFi->database, Out),
>> +                                       OFi->table, IFi->key, cats[i],
>> +                                       ncats[i]);
>> +       else
>> +           ret = db_copy_table_where(IFi->driver, IFi->database, IFi->table,
>> +                                     OFi->driver,
>> +                                     OFi->table, "0 = 1");
>>         if (ret == DB_FAILED) {
>>             G_warning(_("Unable to copy table for layer %d"), fields[i]);
>> Modified: grass/branches/releasebranch_7_2/vector/v.select/main.c
>> --- grass/branches/releasebranch_7_2/vector/v.select/main.c     2017-03-01 11:35:50 UTC (rev 70709)
>> +++ grass/branches/releasebranch_7_2/vector/v.select/main.c     2017-03-01 11:45:44 UTC (rev 70710)
>> @@ -7,7 +7,7 @@
>>   *               Markus Neteler <neteler itc.it>
>>   *               Martin Landa <landa.martin gmail.com> (GEOS support)
>>   * PURPOSE:      Select features from one map by features in another map.
>> - * COPYRIGHT:    (C) 2003-2014 by the GRASS Development Team
>> + * COPYRIGHT:    (C) 2003-2017 by the GRASS Development Team
>> Modified: grass/branches/releasebranch_7_2/vector/v.to.db/main.c
>> --- grass/branches/releasebranch_7_2/vector/v.to.db/main.c      2017-03-01 11:35:50 UTC (rev 70709)
>> +++ grass/branches/releasebranch_7_2/vector/v.to.db/main.c      2017-03-01 11:45:44 UTC (rev 70710)
>> @@ -68,7 +68,7 @@
>>      /* allocate array for values */
>> -    /* (+ 1 is for cat -1 (no category) reported at the end ) */
>> +    /* (+1 is for cat -1 (no category) reported at the end ) */
>>      findex = Vect_cidx_get_field_index(&Map, options.field);
>>      if (findex > -1) {
>>         n = Vect_cidx_get_num_unique_cats_by_index(&Map, findex);
>> @@ -80,7 +80,8 @@
>>      Values = (struct value *) G_calloc(n + 1, sizeof(struct value));
>>      /* prepopulate Values */
>> -    n = Vect_cidx_get_num_cats_by_index(&Map, findex);
>> +    if (findex > -1)
>> +       n = Vect_cidx_get_num_cats_by_index(&Map, findex);
>>      i = 0;
>>      Values[i].cat = -1;                /* features without category */
>>      Values[i].used = 0;
>> Modified: grass/branches/releasebranch_7_2/vector/v.to.points/write.c
>> --- grass/branches/releasebranch_7_2/vector/v.to.points/write.c 2017-03-01 11:35:50 UTC (rev 70709)
>> +++ grass/branches/releasebranch_7_2/vector/v.to.points/write.c 2017-03-01 11:45:44 UTC (rev 70710)
>> @@ -84,7 +84,7 @@
>>                 len = hypot(hypot(dx, dy), dz);
>>                 /* interpolate segment */
>> -               if (interpolate && vert < (LPoints->n_points - 1)) {
>> +               if (vertex == GV_VERTEX && interpolate) {
>>                     int i, n;
>>                     double x, y, z, dlen;
>> Modified: grass/branches/releasebranch_7_2/vector/v.what/main.c
>> --- grass/branches/releasebranch_7_2/vector/v.what/main.c       2017-03-01 11:35:50 UTC (rev 70709)
>> +++ grass/branches/releasebranch_7_2/vector/v.what/main.c       2017-03-01 11:45:44 UTC (rev 70710)
>> @@ -134,6 +134,7 @@
>>         x = window.proj;
>>         G_format_resolution(window.ew_res, ewres, x);
>>         G_format_resolution(window.ns_res, nsres, x);
>>         EW_DIST1 =
>> grass-commit mailing list
>> grass-commit at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-commit
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
Martin Landa
