[GRASS-dev] Testing i.superpixels.slic
Sophie Crommelinck sophie.crommelinck at gmail.com
Thu Mar 2 03:09:21 PST 2017
Hi Moritz,
thank you for your extensive answer! Your reply was very clear and solved
most of my questions, I added two comments in your mail below.
@ Vaclav Petras: You asked to provide the data as well. I uploaded the part
of the orthoimage shown in the screenshots to the same folder:
https://share4land.itc.utwente.nl:5566/sharing/fS3tbiWuW
Thanks again,
Sophie
2017-03-01 16:45 GMT+01:00 Moritz Lennert <mlennert at club.worldonline.be>:
> Hi Sophie !
> On 01/03/17 15:59, Sophie Crommelinck wrote:
>> Hello,
>> thanks a lot for spending time and work implementing /i.superpixels.slic/.
>> It was awesome to see how fast the ticket was addressed, in which I
>> asked if someone would be interested in implementing this addon.
>> I did some initial tests on a UAV orthoimage (Extent: 1000x1000m, GSD:
>> 5cm) and unfortunately it delivered quite different results than a
>> comparable Matlab implementation.
>> What I did:
>>   * i.superpixels.slic on parts of the RGB image with /num_pixels/ =
>>     2500 and /compactness/ = 1
>>     2500 and /compactness/ = 20
>>     2500 and /compactness/ = 1 and /-n/
>>   * I ran the matlab implementation with the same settings
>> What I observed:
>>   * i.superpixels.slic outlines rarely align with the road outlines in
>>     the image.
>>   * Numerous very small superpixels are created (especially for
>>     /compactness/ = 1 and /compactness/ = 1 + /-n/). The total number of
>>     superpixel is much larger than the one defined with /num_pixels/.
>>     The output looks rather like that of a classical edge detector in
>>     textured regions (see screenshots attached).
>> My questions:
>>   * Why does the number of superpixels not correspond to the one defined
>>     in /num_pixels?/
> You might have to increase the number of iterations. The default number of
> 10 is quite low.
I also tested increasing the number of iterations to 100. This resulted in
a lower number of tiny superpixels, but still some superpixels are far away
from being equally shaped compared to the rest. Also this resulted in a
processing time of several hours. I didn't check the effect of changing
step instead of num_pixels.
> Also, consider setting step instead of num_pixels.
>   * How can two implementations both based on Achanta et al. provide
>>     such different results (screenshots attached)?/
> i.superpixels.slic is based on the original Achanta et al C++ code, but it
> is not identical to it. Several choices were made based on the experience
> with our implementation and based on critical review of the original code.
> The basic philosophy of the algorithm is the same. The concrete
> implementation is not.
> I also have no idea if their Matlab code gives the same results as their
> C++ code...
> The meaning of some parameter values is not exactly the same, notably
> compactness. The "compactness" indicator is a weighting criteria between
> the spatial and the spectral distance between a pixel and a superpixel.
> This value is somewhat arbitrary and it is treated slightly differently
> internally in i.superpixels.slic from its treatment in the original code.
> So, you cannot compare compactness=1 between the two implementations.
> In addition, I think that the original code perturbs the location of
> original seeds by default. You might want to set the 'perturb' parameter.
> In short: don't expect similar results using same settings. Just
> experiment with i.superpixels.slic until you get a satisfying result.
> Also don't forget that in GRASS GIS you can input an
Where did the rest of the sentence go?
>>   * The manual says: '/Contrary to the Achanta et al. version of SLIC0,
>>     i.superpixels.slic takes into account the compactness value chosen
>>     by the user even when the *-n* flag is used./' I understand SLICO as
>>     a version of SLIC, for which the compactness//is adaptively refined
>>     for each superpixel. To me, the purpose of SLICO seems to be that
>>     the compactness does not need to be defined and that the superpixels
>>     outlines are more regular-shaped. However, in the manual it sounds
>>     as if -n would rather intend to favor irregular-shaped superpixels.
>>     It is not clear to me, how the GRASS version relates to the usual
>>     SLICO version.
> Achanta et al use the following formula in SLIC for the distance between a
> pixel and a superpixel:
> D^2 = (dc / N)^2 + (ds / S)^2
> where dc is the spectral distance, ds is the spatial distance, S is the
> samplig interval (total number of pixels divided by number of superpixels)
> and N is the maximum spectral distance which varies from cluster to
> cluster. They decided to replace N by a constant m and thus change the
> formula into
> D^2 = (dc / m)^2 + (ds / S)^2
> which they rewrite to
> D^2 = dc^2 + (ds / S)^2 * m^2
> and they consider m as compactness (i.e. when m is high the spatial term
> ds/S gets more important than the spectral term dc^2)
> In SLIC0, they then rewrite this to
> D^2 = (dc / mc)^2 + (ds / ms)^2
> where mc and ms are the "maximum observed spatial and color distances" of
> each cluster in the previous iteration.
> However, that takes away the opportunity for the user to provide a weight
> of spatial vs spectral distance.
> MarkusM thus decided to keep that option of determining a weight (the
> "compactness").
> In i.superpixels.slic, the equation is always:
> D^2 = (dc / m)^2 + c * (ds / S)^2
> where S determined by the step and m is
> - in SLIC: the maximum spectral distance observed amongst all clusters
> - in SLIC0: the maxium spectral distance in each cluster separately.
> I agree that one can argue about the question whether this implementation
> should still be called SLIC0, but it it sufficiently close to the original,
> while, IMHO, improving it, that I think that it still warrants the name.
> Moritz
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170302/d4ce291d/attachment.html>
