[GRASS-dev] Temporal GIS: registering maps with infinite values
Sören Gebbert
soerengebbert at googlemail.com
Sun Mar 5 00:07:01 PST 2017
It seems that sqlite does nor support "inf" as valid numerical value.
There is no fast fix available for this issue. Can you avoid computing
infinite values?
Best regards
Soeren
2017-03-04 0:25 GMT+01:00 Laurent C. <lrntct at gmail.com>:
> Hello,
> I have some raster maps that have infinite values:
> r.univar map=out_v17.2dev_theta7_fr_0005 at EA2DT8A
> total null and non-null cells: 96400
> total null cells: 1840
> Of the non-null cells:
> n: 94560
> minimum: 0.000291453
> maximum: inf
> range: inf
> mean: inf
> mean of absolute values: inf
> standard deviation: -nan
> variance: -nan
> variation coefficient: -nan %
> sum: inf
> When trying to register them in a STRDS, I get an SQL error:
> File "/home/laurent/Program/itzi/itzi/gis.py", line 452, in
> register_maps_in_stds
> unit=t_unit[t_type])
> File "/usr/lib/grass72/etc/python/grass/temporal/register.py", line
> 499, in register_map_object_list
> file=filename, dbif=dbif)
> 325, in register_maps_in_space_time_dataset
> dbif.execute_transaction(statement)
> File "/usr/lib/grass72/etc/python/grass/temporal/core.py", line
> 1021, in execute_transaction
> return self.connections[mapset].execute_transaction(statement)
> 1315, in execute_transaction
> self.cursor.executescript(statement)
> OperationalError: no such column: inf
> I'm using GRASS 7.2.0
> Is there a solution to that issue?
> Regards,
> Laurent
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
