[GRASS-dev] RGB colored and Transparent areas in one vector map
Vaclav Petras wenzeslaus at gmail.com
Mon Mar 6 06:00:41 PST 2017
On Mon, Mar 6, 2017 at 6:44 AM, Nikos Alexandris <nik at nikosalexandris.net>
wrote:
> I have an rgb_column with RGBs for a vector map. For some areas, I would
> like to have no color, as in trasparent.
> If I am not wrong, we can't do that, ie define "nv" as we can do in
> color rules for a raster map.
Try setting the column value to "none" (usually implemented for parameters,
I'm not sure here).
Note that "nv" is 'no value' (NULL), not 'no color' in the color rules
syntax.
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170306/8b523806/attachment-0001.html>
