[GRASS-dev] [GRASS GIS] #3309: Avoid errors in parallel creation of tempfiles
trac at osgeo.org
Tue Mar 7 02:05:41 PST 2017
Reporter: sbl | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.2.1
Component: LibGIS | Version: svn-releasebranch72
Resolution: | Keywords: G_tempfile()
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [ticket:3309 sbl]:
> When tempfiles are created in parallel, conflicts and thus fatal errors
can arise when two processes try to create the .tmp/HOST dir at the same
time:
> https://lists.osgeo.org/pipermail/grass-dev/2017-March/084471.html
> The conflict seems to arise only from the directory.
> So, maybe it could help if the directory is created at the start of a
GRASS session and removed only when the GRASS session is closed (exit)?
Now that you mention it, I can confirm that I've also been confronted to
such errors when running commands in parallel that create temp files. So
+1 to needing a solution.
I don't know though if the best is to create this directory once and for
all at the startup, or whether the tempfile routines in lib/gis/tempfile.c
could be modified to avoid such race conditions.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3309#comment:1>
