[GRASS-dev] [GRASS GIS] #3311: Mismatch between CLI and GUI for r.colors using external rules file
trac at osgeo.org
Wed Mar 8 04:42:43 PST 2017
Reporter: madi | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.colors
CPU: Unspecified | Platform: Unspecified
Comment (by hellik):
Replying to [ticket:3311 madi]:
> There is a mismatch between the command line and the GUI of r.colors
when providing an external file for color rules. Via command line the
correct (working) command is:
> r.colors map=map_name rules=rules.file
> but via GUI, browsing the rules.file, it will build the following
command:
> r.colors map=map_name file=rules.file
taken from the manual:
file=name
Input file with one map name per line
Input map names can be defined in an input file in case a large amount
of maps must be specified. This option is mutual exclusive to the map
option.
''file'' is on the first r.colors-GUI-tab, rules is on the second r
.colors-GUI-tab.
I would say it works normal. ;-)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3311#comment:2>
