[GRASS-dev] Pygrass - Getting pixel infos from a raster map
Sören Gebbert soerengebbert at googlemail.com
Tue Mar 14 14:02:37 PDT 2017
The class pygrass.raster.RasterSegment is not directly related to the
output created by i.segment.
It is a class to allow random read and write access to very large
raster layers, that do not fit into the main memory.
Please use pygrass.raster.RasterRow[1] from grass7.2 for row-wise
access to raster maps.
Best regards
Soeren
[1] https://grass.osgeo.org/grass70/manuals/libpython/pygrass.raster.html#pygrass.raster.RasterRow
2017-03-14 20:18 GMT+01:00 Lucas lefevre <lucas.lefevre at hotmail.com>:
> Hi,
> I'm new to Grass and Grass development.
> I'm writing a script using pygrass that should interact with areas in a
> raster map (output of i.segment). The final goal would be to highlight some
> of them to the user.
> But I can't even figure out how get infos from the different segments or
> even the raw pixels.
> When instantiating a RasterSegment object
> (https://grass.osgeo.org/grass70/manuals/libpython/pygrass.raster.html#pygrass.raster.RasterSegment)
> and using the method .get(row, col) it gives me -2147483648 for .get(0,0)
> and other values for 'row' and 'col' give 0.
> This doesn't make any sense to me, am I missing something ?
> (Note that both .exist() and .is_open() give True on the RasterSegment
> object)
> Any help would be appreciated !
> Lucas
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
