[GRASS-dev] [GRASS GIS] #3315: wingrass: provide grass.bat
GRASS GIS trac at osgeo.org
Wed Mar 15 05:33:31 PDT 2017
  Reporter:  martinl       |      Owner:  grass-dev@…
      Type:  enhancement   |     Status:  new
  Priority:  normal        |  Milestone:  7.2.2
 Component:  Installation  |    Version:  svn-trunk
Resolution:                |   Keywords:  wingrass
       CPU:  Unspecified   |   Platform:  Unspecified
Comment (by jef):
 I'd consider conflicting files a packaging bug - so this should probably
 be a separate package
 Perhaps with a env variable that allows to control, which version to load.
 Could be done using a {{{etc/ini/packagename.bat}}} - which wouldn't
 produce a conflict.  Although that might produce the above behaviour (last
 ini wins).  Not sure if there is a defined order in which the ini
 batchfiles are executed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3315#comment:1>
