[GRASS-dev] custom CRS
Moritz Lennert
mlennert at club.worldonline.be
Sat Mar 18 04:26:15 PDT 2017
Le 18 mars 2017 10:06:09 GMT+01:00, Paulo van Breugel <p.vanbreugel at gmail.com> a écrit :
>Dear all,
>I have a shapefile which is in CRS ESRI:37203 [1], which is defined in
>the prj file as
>GEOGCS["GCS_Everest_India_Nepal",DATUM["D_Everest_India_Nepal",SPHEROID["Everest_Definition_1962",6377301.243,300.8017255]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]]
>The corresponding proj.4 definition (as defined in the esri epsg-codes
>file in /usr/share/proj/)
>+proj=longlat +a=6377301.243 +b=6356100.230165384 +no_defs
>And when I create a location based on this shapefile, the projection
>information is:
>-PROJ_INFO-------------------------------------------------
>a : 6377301.243
>es : 0.006637846068423442
>proj : ll
>no_defs : defined
>-PROJ_UNITS------------------------------------------------
>unit : degree
>units : degrees
>meters : 1.0
>Question 1: Now, I can import a shapefile or raster layer in
>latlon/WGS84 (EPGS: 4326) without reprojection. GRASS thus assumes the
>projection is identical, even if they are not? Why is that?
>The proj.4 definition above is missing the shift w.r.t. the WGS84.
That would be why: if no towgs84 info is given, the projection is assumed as using wgs84 as datum.
>The
>correct proj.4 definition for EPGS 37203 would be [2]
>+proj=longlat +a=6377301.243 +b=6356100.2284
>+towgs84=295,736,257,0,0,0,0 +no_defs
>Question 2: In QGIS it is possible to define a custom CRS using the
>above. Can I do this in GRASS as well, and if so, how?
The location creation wizard allows you to define a location using a proj.4 string.
>Or can / should
>I
>add this to the datum information files in $GISBASE/etc/proj/ogr_csv?
Not sure about that file, but you could also add it directly in the /use/share/project/epsg or equivalent.
Moritz
>Regards,
>Paulo
>[1] https://epsg.io/37203
>[2]
>https://disqus.com/home/discussion/qgistutorials/georeferencing_topo_sheets_and_scanned_maps/#comment-1426454689
>_______________________________________________
>grass-dev mailing list
>grass-dev at lists.osgeo.org
>https://lists.osgeo.org/mailman/listinfo/grass-dev
