[GRASS-dev] [GRASS GIS] #3318: t.list: output and separator options not working properly
trac at osgeo.org
Sun Mar 19 15:21:16 PDT 2017
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: Temporal | Version: svn-trunk
Keywords: t.list | CPU: x86-64
Platform: Linux |
When trying to use {{{t.list type=raster output=map_list}}}, I found that
output option does not work as expected. If I used the standard output,
all maps are listed, but when using output option only a part of the maps
were listed in the resulting file. This is maybe related to #3316.
On the other hand, the option separator seems insensitive, both if I use
standard output and a file, I always get one map per line. I tried with
separator=comma and separator=pipe, for type=strds and type=raster. The
output is always one map (or strds) per line.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3318>
