[GRASS-dev] [GRASS GIS] #3309: Avoid errors in parallel creation of tempfiles
trac at osgeo.org
Fri Mar 24 10:51:11 PDT 2017
Reporter: sbl | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.2.1
Component: LibGIS | Version: svn-releasebranch72
Resolution: | Keywords: G_tempfile()
CPU: Unspecified | Platform: Unspecified
Comment (by sbl):
For the record:
Running
rm -f "`g.tempfile pid=$$`"
in advance works around the issue.
Using GRASS 7.2.1svn (r70188) in BATCH mode I do get the error message
above. But if I run g.tempfile and make sure that the tmp directory is
created before I run r.in.gdal through xargs, everything works just fine!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3309#comment:4>
