[GRASS-dev] [GRASS GIS] #3319: v.overlay: incorrect results with "not" operator
GRASS GIS trac at osgeo.org
Sat Mar 25 14:25:35 PDT 2017
  Reporter:  sbl          |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  major        |  Milestone:  7.2.1
 Component:  Vector       |    Version:  svn-releasebranch72
Resolution:               |   Keywords:  v.overlay
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mmetz):
 Replying to [ticket:3319 sbl]:
 > In a project I want to clip away the sections from a river network that
 are within lakes.
 > Unfortunately, some streams vanished from the result completely (which
 should not)...
 Please try v.overlay in trunk r70800.
 The problem lies with Vect_break_lines() and Vect_break_lines_list() which
 create new vertices that are sometimes too close to existing vertices
 (floating point representation error). Radim was aware of that problem in
 v.overlay. I (hopefully) fixed the symptom in v.overlay. The real fix
 would be to not use a fixed value for rethresh (Radim was also aware of
 that problem) in Vect_line_intersection() and Vect_line_intersection2(),
 but instead set rethresh to the smallest representable difference (ULP).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3319#comment:1>
