[GRASS-dev] [GRASS-SVN] r70814 - grass-addons/grass7/raster/r.vif
Vaclav Petras
wenzeslaus at gmail.com
Tue May 2 12:02:21 PDT 2017
On Fri, Mar 31, 2017 at 8:56 AM, <svn_grass at osgeo.org> wrote:
> Author: pvanbosgeo
> Date: 2017-03-31 05:56:38 -0700 (Fri, 31 Mar 2017)
> New Revision: 70814
> Modified:
> grass-addons/grass7/raster/r.vif/r.vif.html
> grass-addons/grass7/raster/r.vif/r.vif.py
> Log:
> r.vif addon: computation of vif is now in Python, resulting in strongly
> reduced computing times. There is an option to use a random subsample of
> raster cells as input to further speed up the computations. There is
> furthermore a 'low-memory' option (this is the old implementation which
> uses r.regression.multi).
# import libraries
> import os
> import sys
> import math
> import numpy as np
> -import grass.script as grass
> +from scipy import stats
Hi Paulo,
it seems that the scipy is not used. I would just remove the line to make
the module work on computers without scipy, but you may be still planning
some changes, so I don't want to interfere. Please let me know.
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170502/65b87063/attachment.html>
