[GRASS-dev] Broken: GRASS-GIS/grass-ci#2145 (master - d37fa7c)
Vaclav Petras
wenzeslaus at gmail.com
Sat May 6 15:36:12 PDT 2017
On Fri, May 5, 2017 at 6:36 AM, Travis CI <builds at travis-ci.org> wrote:
> GRASS-GIS / grass-ci (master)
> Build #2145 was broken.
> git-svn-id: https://svn.osgeo.org/grass/grass/trunk@71024
15284696-431f-4ddb-bdfa-cd5b030d7da7
> We have updated our sudo-enabled Precise images! Read our blog post for
more details. Thank you!
There is some issue with packages in the Travis build:
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libgdal-dev : Depends: libgdal1h (= 1.10.0-1~precise2) but it is not going
to be installed
The build fails with error:
checking for location of External PROJ.4 includes...
checking for proj_api.h... no
configure: error: *** Unable to locate External PROJ.4 includes.
include/Make/Vars.make:1: include/Make/Platform.make: No such file or
directory
make: *** No rule to make target `include/Make/Platform.make'. Stop.
The Travis build is based on Ubuntu 12.04 Precise and uses
ppa:ubuntugis/ubuntugis-unstable which seems to support 12.04. The missing
file is from libproj-dev. I don't have the this issue on 16.04. That's all
I have now.
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170506/1e5da93e/attachment.html>
