[GRASS-dev] [GRASS GIS] #3296: r.mapcalc: nmedian() unexpected results
GRASS GIS trac at osgeo.org
Sun May 7 12:28:01 PDT 2017
  Reporter:  sbl          |      Owner:  grass-dev@…
      Type:  defect       |     Status:  reopened
  Priority:  normal       |  Milestone:  7.2.1
 Component:  Raster       |    Version:  svn-releasebranch72
Resolution:               |   Keywords:  r.mapcalc,nmedian()
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mmetz):
 Replying to [comment:7 neteler]:
 > Replying to [comment:6 mmetz]:
 > > Replying to [comment:2 marisn]:
 > > > In [changeset:"70674" 70674]:
 > > > #!CommitTicketReference repository="" revision="70674"
 > > > Do not calculate median if only one variable is provided.
 > > > Fixes #3296
 > > Fixed in trunk r70683. You need to use the actual number of non-NULL
 values to set the pointers a1, a2.
 > Does(n't) this need to be backported?
 Already done in r70684 (Feb 2017).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3296#comment:8>
