[GRASS-dev] Having trouble building GRASS from source and asking for help
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Tue May 16 00:37:23 PDT 2017
To me this looks like checkinstall is failing caus not all required metainformation is given.
See: https://manpages.debian.org/jessie/checkinstall/checkinstall.8.en.html
Try specifying amongst others - -pkgversion
Hope that helps...
Cheers
Stefan
________________________________________
Von: grass-dev [grass-dev-bounces at lists.osgeo.org] im Auftrag von Paul Schrum [paul.schrum at gmail.com]
Gesendet: Montag, 15. Mai 2017 22:14
An: grass-dev at lists.osgeo.org
Betreff: [GRASS-dev] Having trouble building GRASS from source and asking for help
I am attempting to build GRASS on my machine and I suppose I am having trouble. I am so bewildered by all of this I can't actually be sure. I am posting to request help. Here is my situation:
I am new to GRASS development, and I am working on GSoC on integrating PDAL interoperability. I have not yet set up my project's wiki page or I would link it in this sentence.
I am running OSGeo-live on Oracle Virtual Box with my base OS being Windows 8.1.
My mentor, Vashek Petras, directed me to start here: https://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#Dependencies
and work through the build procedure. On that page, I got down as far as "simple configure, compile and install" and ran that once. I don't remember what it told me, but I figured it was okay since I could always do it again, so I executed the next line (under the "or"):
./configure && make -j2 && sudo checkinstall
When I do this, I get the message
Building Debian package... FAILED!
so I am thinking this is bad and I should get this to succeed before moving on to other steps. Here is more information: When I try to run it again, I get a screen of Warnings:
checkinstall 1.6.2, Copyright 2009 Felipe Eduardo Sanchez Diaz Duran
This software is released under the GNU GPL.
**** Debian package creation selected ***
*** Warning: The package name "%PACKAGE_NAME" contains upper case
*** Warning: letters. dpkg might not like that so I changed
*** Warning: them to lower case.
*** Warning: The package name "%package_name" does not start with
*** Warning: an alphanumetic character. dpkg might not like that so I prefixed
*** Warning: it with a number 0.
*** Warning: The package name "0%package_name" contains illegal
*** Warning: characters. dpkg might not like that so I changed
*** Warning: them to dashes.
*** Warning: The package version "%PACKAGE_VERSION" is not a
*** Warning: debian policy compliant one. Please specify an alternate one
I let it continue to run, but eventually it offers to show me the log, which appears here:
dpkg-deb: error: parsing file '/var/tmp/tmp.J1ZMR3Tl3Q/package/DEBIAN/control' near line 11 package '0-package-name':
empty value for version
/var/tmp/tmp.J1ZMR3Tl3Q/dpkgbuild.log (END)
Is this enough information for someone to help me?
- Paul Schrum
Raleigh, NC, US
