[GRASS-dev] t.rast.what flags
Sören Gebbert
soerengebbert at googlemail.com
Tue May 16 08:18:56 PDT 2017
Hi Luca,
for what or why do you need the additional flags for r.what?
Ciao
Sören
2017-05-16 15:04 GMT+02:00 Luca Delucchi <lucadeluge at gmail.com>:
> Hi devs,
> I'm working on t.rast.what and I discovered that flags are not used in
> the calling r.what module.
> The comment said they are disabled for test issues [0], I think it is
> more important to have these flags working and some problems test
> problem instead don't use at all the flags.
> What do you think?
> [0] https://trac.osgeo.org/grass/browser/grass/trunk/temporal/t.rast.what/t.rast.what.py#L188
> ciao
> Luca
> www.lucadelu.org
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
