[GRASS-dev] t.rast.what flags
Sören Gebbert soerengebbert at googlemail.com
Tue May 16 08:53:41 PDT 2017
Feel free to modify t.rast.what. However, i found it too complicated
to add category/attribute output to r.what/t.rast.what so i
implemented t.rast.sample that does it more elegant and outputs
category and vector attributes:
https://bitbucket.org/huhabla/temporal-raster-sampling
Ciao
Sören
2017-05-16 17:38 GMT+02:00 Luca Delucchi <lucadeluge at gmail.com>:
> On 16 May 2017 at 17:18, Sören Gebbert <soerengebbert at googlemail.com> wrote:
>> Hi Luca,
> Hi Sören,
>> for what or why do you need the additional flags for r.what?
> I just added a new flag in r.what to return also the cat of feature
> and I would add this capability also to t.rast.what because I'm doing
> a new module using this feature...
>> Ciao
>> Sören
> ciao
> Luca
> www.lucadelu.org
