[GRASS-dev] [GRASS-SVN] r71093 - grass/trunk/vector/v.in.ogr
Martin Landa
landa.martin at gmail.com
Wed May 17 06:09:34 PDT 2017
2017-05-17 15:00 GMT+02:00 <svn_grass at osgeo.org>:
> + /* TODO: remove below code, or use it in e.g. a new v.in.pg */
-1
v.in.ogr should work for all datasources. Special care should be done
for database sources. Connection string can be provided as fully
qualified. But also stored connections (via db.login) should be also
taken into account. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
