[GRASS-dev] [GRASS GIS] #3348: wxGTK3: Gtk-CRITICAL **: gtk_box_gadget_distribute: assertion 'size >= 0' failed in GtkSpinButton
trac at osgeo.org
Wed May 17 14:14:00 PDT 2017
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: wxGUI | Version: svn-trunk
Keywords: wxGUI | CPU: Unspecified
Platform: Unspecified |
The terminal gets flooded with such warnings (I am using wxGTK3-3.0.3 on
Fedora).
To reproduce:
d.vect --ui
## switch to "Line" tab
(forms.py:5716): Gtk-CRITICAL **: gtk_box_gadget_distribute: assertion
Related comment:
On Wed, May 17, 2017 at 3:18 AM, <bugzilla at redhat.com> wrote:
> https://bugzilla.redhat.com/show_bug.cgi?id=1411165
> --- Comment #15 from Scott Talbert ---
>> (wxgui.py:4072): Gtk-CRITICAL **: gtk_box_gadget_distribute: assertion
'size >= 0' failed in !GtkCheckButton
> The latter one is likely that there isn't enough space allocated for a
check
> button widget - most likely has to be fixed in GRASS.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3348>
