[GRASS-dev] error when running v.distance in python script
Paulo van Breugel p.vanbreugel at gmail.com
Fri May 19 06:50:48 PDT 2017
Hi devs
I am trying to use v.distance in a Python script. However, I am getting
the error
Module("v.distance", from=tmpout3, to=tmp_val, upload="to_attr",
        column="x", to_column=column)
   File "<ipython-input-138-da4ba6c2bb80>", line 1
SyntaxError: invalid syntax
If I run the same directly on the command-line it runs without errors.
v.distance from=testmap1 to=testmap2 upload=to_attr column=x to_column=lv
Is this because 'from' is a reserved word perhaps? If so, how do I use
this in a Python script? Otherwise, any idea what I might be doing wrong?
