[GRASS-dev] [GRASS GIS] #2732: Read lidar data as vector points using PDAL
trac at osgeo.org
Sun May 21 20:34:46 PDT 2017
Reporter: wenzeslaus | Owner: wenzeslaus
Type: | Status: new
enhancement |
Priority: major | Milestone: 7.4.0
Component: Vector | Version: svn-trunk
Resolution: | Keywords: lidar, las, laz, v.in.lidar,
CPU: | v.in.pointcloud, v.in.pdal
Unspecified | Platform: Unspecified
Comment (by hobu):
There have been a number of PDAL developments since this ticket was first
developed that might be interesting in relation to this task:
1) The PDAL
[https://github.com/PDAL/PDAL/blob/master/pdal/PipelineExecutor.hpp
PipelinExecutor] class allows you to insert PDAL Pipeline JSON and get
back PDAL PointViews quite easily. This means no more manual or laborious
pdal::Stage construction. The executor class can hide all of that for you.
Dig in the Python or Java extensions for inspiration on how to use it.
2) PDAL is now available via OSGeo4W64. We won't be committing to
maintaining the 32-bit builds, but the 64-bit builds will be generated as
part of PDAL's continuous integration and included in all major PDAL
releases.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2732#comment:15>
