[GRASS-dev] [GRASS GIS] #3349: v.import: add 'where' parameter
trac at osgeo.org
Mon May 22 02:57:42 PDT 2017
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.4.0
Component: Vector | Version: unspecified
Resolution: | Keywords: v.import where
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:3 mmetz]:
> Replying to [comment:2 mlennert]:
> > Replying to [comment:1 mmetz]:
> > > Replying to [ticket:3349 mlennert]:
> > > > Was there choice of not adding a 'where' parameter to v.import a
deliberate one ? I would find this parameter quite useful, but do not want
to implement it if there was an explicit decision against it.
> > > The reason to not add a 'where' option to v.import, as well as
various other options and flags present in v.in.ogr but not in v.import,
was to provide a module with a simplified user-interface that combines
v.in.ogr + v.proj. It was not meant to be a replacement for using v.in.ogr
and v.proj separately.
> > Well, the fact that AFAICT the GUI now exclusively uses v.import for
imports (even when you chose "Common import formats" and **not** "Import
of common formats with reprojection") and automatically proposes to
reproject data at import if it is not in the location's projection,
creates a situation where most people will use v.import, without knowing
it.
> When you choose "Common import formats", you get a custom GUI interface
to v.in.ogr, not the interface of v.in.ogr --ui
(gui/wxpython/xml/wxgui_items.xml). That means the 'where' option (and
others) is missing in the custom GUI interface to v.in.ogr. Similar for
r.in.gdal (Import raster data -> Common formats import).
These custom GUIs now directly call v./r.import. The only difference
between the first and second menu entries in the respective GUI menus is
that the first calls the GUI wizard (which then calls v./r.import) and the
second calls the v./r.import module GUI.
If the wizard calls the *.import modules, then I think it would be better
to have as second entry a call to the original v.in.ogr/r.in.gdal module
GUIs in the menu, instead of the v.import GUI which does not bring much
added value in comparison to the wizard...
This would allow to increase the visibility of the original modules and
their additional options.
> Any reason why the menu entry for v.in.ogr is "Common import formats"
while for r.in.gdal it is "Common formats import"?
None to my knowledge.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3349#comment:4>
