[GRASS-dev] Need help in writing a program in Grass GIS
pablo zader
pzader at gmail.com
Tue May 23 07:39:56 PDT 2017
Hi CM,
You can use:
http://grasswiki.osgeo.org/wiki/GRASS_Python_Scripting_Library
Or,
https://grass.osgeo.org/grass70/manuals/libpython/pygrass_index.html
El 23/5/2017 11:12 a. m., "Luca Delucchi" <lucadeluge en gmail.com> escribió:
On 21 May 2017 at 20:03, CM Reddy <chalamcharla en hotmail.com> wrote:
> Hi All,
> I am new to GIS and GRASS also. We would like to use the GRASS source and
> implement the following features.
> Import a shape file.
> Select a start location and end location in the map. Connect start and end
> locations with some intermediate points. Each point or location should
> uniquely identified with lat and long.
> Associate predefined properties for each identified point.
> Store the each location and it's properties in a data base.
> We would like to implement the above feature as additional menu in the
> existing toolbar. We would like to implement required dialog boxes or UI
> panel to display lat and long assocaited with identified locations. GUI
> should has the provision to enter properties for each location. Finally,
we
> need to store them in DB after clicking a SAVE button.
> I request your help in building the above application. I have already
> downloaded and compiled the GRASS 7.2 on ubuntu successfully.
> How to extend the current GRASS application ?
GRASS is composed by singular modules, so it is quiet simple to extent
> How to build the supporting the GUI ?
https://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/README
wxpython/xml/menudata.README
> Can I write a python script to build the above application ?
yes
> What are the modules to be written ?
probably none, I think all modules you need are already in GRASS
> - Thanks
> CM
ciao
Luca
www.lucadelu.org
grass-dev mailing list
grass-dev en lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
------------ próxima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170523/1e114f62/attachment.html>
