[GRASS-dev] Gaining write privileges to usr/local and subdirectories
Paul Schrum
paul.schrum at gmail.com
Tue May 23 08:12:24 PDT 2017
Is there a way I can give myself privileges in my own usr/local to write to
it and its subdirectories?
In following the directions to build grass7_trunk, I put the source under
/usr/local/src/grass7_trunk, and now everything I do which modifies
anything must be preceeded with sudo. I would like to eliminate this
requirement for day-to-day work.
Thanks.
- Paul
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170523/94f2570c/attachment.html>
