[GRASS-dev] Gaining write privileges to usr/local and subdirectories
Helmut Kudrnovsky
hellik at web.de
Tue May 23 08:35:13 PDT 2017
Paul Schrum wrote
> Is there a way I can give myself privileges in my own usr/local to write
> to
> it and its subdirectories?
> In following the directions to build grass7_trunk, I put the source under
> /usr/local/src/grass7_trunk, and now everything I do which modifies
> anything must be preceeded with sudo. I would like to eliminate this
> requirement for day-to-day work.
here on my debian, I put the grass source code in my /home/ directory [1]
and do there all my coding and compiling. maybe not the best practice, but
no chown/chmod needed.
[1] https://wiki.debian.org/FilesystemHierarchyStandard
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Gaining-write-privileges-to-usr-local-and-subdirectories-tp5321487p5321498.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
