[GRASS-dev] [GRASS-user] v.to.db area calculations
Moritz Lennert
mlennert at club.worldonline.be
Wed May 24 06:02:54 PDT 2017
On 24/05/17 11:39, James Duffy wrote:
> Please find the polygon in the zip attached.
[sent offlist]
Ok, I can confirm that there is a problem with this particular polygon.
I guess that it might an issue with the very small size of this polygon.
When I import it in an EPSG 4326 location, I get the same result as you:
> v.report training op=area u=me
cat|id|area
1|1|38.2256243922775
But when I reproject it to a UTM 43N (EPSG 32743) location, I get a
different area, which is close to what you find in QGIS:
v.proj location=LL_WGS84 mapset=mlennert input=training
output=training_reproj_grass
v.report training_reproj_grass op=area u=me
cat|id|area
1|1|0.126369981910102
Interestingly, when I create a buffer around the area:
v.buffer training dist=0.0001 out=training_buff_0_0001
The area measurement in GRASS is again very close to the one in QGIS:
v.report training_buff_0_0001 op=area u=me
cat|area
1|419.188654810375
$area in field calculator in QGIS:
425.1112801
And in the ESPG 4326 location, it is impossible to zoom to the original
polygon as it seems to go below the zoom capacity of the GUI:
"Failed to run command 'd.vect map=training at mlennert
type=point,line,boundary,area,face width=1'. Details:
GRASS_INFO_ERROR(22724,1): Invalid n-s resolution field: 0.000000 "
Although these two might be unrelated, I do feel that there might be an
issue with floating point precision somewhere...
Could you post this as a bug report, including your polygon ? Or would
you prefer me posting the report, but could I then use your polygon ?
Moritz
