[GRASS-dev] Issue with db.execute: error altering a PostGIS table
Martin Landa landa.martin at gmail.com
Wed May 24 23:26:51 PDT 2017
2017-05-25 8:26 GMT+02:00 Martin Landa <landa.martin at gmail.com>:
>> The situation is that user ${TARGETDB_USER_TEST_ADMIN} has the
>> permission to see schema "test". This user is the only one who may
> you need to have at least select permission on schema where PostGIS
> functions lives (usually it's public schema).
also 'public' schema must be in the search path (set search_path to ...). Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
